Old 05-21-2013, 12:37 PM   #1
m455sx
m455sx's Avatar
Rear Shocks
I am wondering what year shocks i have on the rear. It doesn't seem to be stock 62 rear hence the 12 bolt and shock locations.
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline   Reply With Quote
Old 05-21-2013, 12:42 PM   #2
robber grin
Re: Rear Shocks
Looks like factory shock placement to me. Which could still work with a rear-end swap.
They are fairly long and I was just asking N@P@ for a reference and there was no listing for 1962.
best of luck -
rg
robber grin is offline   Reply With Quote
Old 05-21-2013, 12:44 PM   #3
m455sx
m455sx's Avatar
Re: Rear Shocks
I have seen factory literature of a 62 chassis and it showed shocks infront of rear and running at an angle towards the center of truck.
1970 Cutlass SX
1962 Chevy Stepside
Old 05-21-2013, 02:13 PM   #4
Greg63
Enjoy your truck
Greg63's Avatar
Re: Rear Shocks
To my eye, it looks like the lower shock brackets are swapped from left side to right side, and turned 180 degrees so they are facing rearward. The shocks should be ahead of the rear axle and mount on a forward angle toward the front of the truck.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 05-21-2013, 02:27 PM   #5
m455sx
m455sx's Avatar
Re: Rear Shocks
Greg.
I thought the same as you on original factory placement of the shocks. Now here the Question how is the best way to measure the shocks to find replacements.
1970 Cutlass SX
1962 Chevy Stepside
Old 05-21-2013, 04:11 PM   #6
LVPhotos
LVPhotos's Avatar
Re: Rear Shocks
That looks right. Measure ride height eye to eye. Normally you would add 3" up and minus 3" down. So a ride height of 17" would be an extended length of around 20" and a collapsed 14". Factor in if you want bags you want an x amount of collapse and y amount droop. Be realistic on how much you cycle the suspension. A 6" stroke is fine for stock. Ask a local shop if in doubt.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-21-2013, 04:12 PM   #7
verdell
verdell's Avatar
Re: Rear Shocks
It looks like factory '62 lower shock brackets with '65 or newer 12 bolt rear. I have exact same set up on my '60 & '61. Try Gabriel part number 82086.
verdell is offline   Reply With Quote
