Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-21-2013, 10:45 PM   #1
dmartin1
dmartin1's Avatar
Which rearend.options? built 454
well, i picked up a pretty rowdy 454 .030 over a bit back and am in process of getting it buttoned up.it was out of a sunken v drive boat( for about 1 hour) taken apart and all cleaned up. in the 550hp/tq neighborhood.(will have a question thread on this, engine related as well)
anywho, my truck is an '82 stepside 5 lug. 10 bolt. factory rearend. truck has a straight 6 factory.
is this thing even gonna hold up to this engine at all? im not gonna be hard launching,simply a rowdy toy to fly around in and get on every here and there.
what are my best options as far as rearends go? i definately dont have 1000+ for a company built performance rearend. cheaper the better, but i know quality dont come cheap.
wheels are uni-5 lug.i plan on posi/locker.
am i gonna need the ford 9"? 12 bolt? 10 bolt?
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 05-22-2013, 12:30 AM   #2
tinydb84
tinydb84's Avatar
Re: Which rearend.options? built 454
As long as you dont get traction you might be fine. A nice 12 bolt should be okay.
David
Instagram: myfabguy
Old 05-22-2013, 02:45 AM   #3
Captainfab
60-66 Nut
I agree. The 8.5 10 bolt will live for a while if you don't run sticky tires. An easy and affordable upgrade would be the '73-'82 12 bolt. Drop in a posi or locker, slide in some upgrade axles, and you'll be good for a bit of abuse.
Old 05-22-2013, 11:13 AM   #4
dmartin1
dmartin1's Avatar
does my '82 10 bolt have the same width as that 12 bolt your talking about?
i am running 295/50/15 on a 10" or 11" wide wheel.they grab,but not a ton.they are bfg radial ta's
would i be better fixing the rearend i got('82 10 bolt) and cruise it and save for a decent 12 bolt build?
65 nova
And more
Old 05-22-2013, 10:32 PM   #5
Captainfab
60-66 Nut
Yes. All '71-'87 C10/K10 differentials are the same width, regardless whether it is a 10 bolt or 12 bolt. I wouldn't be afraid to run the current 10 bolt until you can put together a good 12 bolt.
Old 05-31-2013, 04:04 PM   #6
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
I agree that you can get by with the 12 bolt however I would warn against spend much money on the 12 bolt it will add up fast and in the end a 9 inch is going to be a much stronger item.. Moser sells 100% bolt in units.. I bought the 35 spline wave loc yada yada unit.. It is flawless and I never have to worry about hooking it up hard just go have fun.. I priced out the 12 bolt but when you do it right you have already bought the 9 inch good luck
GMR-PERFORMANCE is offline   Reply With Quote
Old 05-31-2013, 11:02 PM   #7
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Dana 60 and be done with it.
prostreetC-10 is offline   Reply With Quote
Old 06-02-2013, 12:12 AM   #8
dmartin1
dmartin1's Avatar
HMM, well i think im going to slap this 8.5 back together and save for a descent 9 inch on craigslist or ebay, if i can find one.ill just have to try and keep my foot out of it. maybee.
thanks for the opinions guys and gals.
** if anyones still readin, any links or leads on where i can get the axle bearings for this 8.5 10 bolt at? ive been looking but cant find them.idk what im doing wrong.
65 nova
And more
Old 06-02-2013, 12:17 AM   #9
Captainfab
60-66 Nut
You should be able to get the axle bearings and any other parts for your 8.5 10 bolt at most local auto parts suppliers.
Old 06-03-2013, 01:56 PM   #10
ripdog28
ripdog28's Avatar
I have a custom housing built by Currie and love it but do not believe it is necessary for a street vehicle. IMO, Call up a reputable company, Currie, Mosier, ect and talk to them about things you could do to make the 10bolt work, rear brace, axles, ect.... That would save you a bunch. They may say a 10 bolt can not handle the power.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 06-10-2013, 01:24 PM   #11
Jon01
Jon01's Avatar
This is the best answer yet.
D60 is right up there with a 9" and I thought they came under some 3/4 tons?
If so you're just a set of custom axles away from a very tough rearend.
No need for big $ custom fabbed stuff.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
