Old 05-22-2013, 05:49 PM   #1
Oleblu1
Need pics or some flip drops pls.
Hello everyone i am new here, i have owned 3 C10's and i have lowered the rear by just yanking out some leaf springs. Can you post some pics of some flip jobs and what kind of drop is acheived by this method. Thanks and welcome any advice.
Oleblu1 is offline   Reply With Quote
Old 05-22-2013, 08:35 PM   #2
wraprail
wraprail's Avatar
Re: Need pics or some flip drops pls.
Welcome!
Here is a pic of my homemade flip. Lower spring plate/shock mount is from speedway motors. U bolts are factory. Spring pads are speedway motors.
Gives a 5-6 inch drop depending on how thick your leaf springs are.
wraprail is offline   Reply With Quote
Old 05-22-2013, 08:47 PM   #3
Oleblu1
Thanks, not really a good welder but is there a bolt on application? Or is that even possible.
Old 05-22-2013, 09:32 PM   #4
J Knight
J Knight's Avatar
5in flip with the bump stop bracket removed.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 05-22-2013, 11:28 PM   #5
Oleblu1
Thanks! While I am picking brains, can I change out the oil pan gasket without pulling the motor? Truck had been sitting for years and I would like to change out all the gaskets seals water pump timing chain etc.
Thanks for all the help also.
Old 05-22-2013, 11:46 PM   #6
izzy_Britton
izzy_Britton's Avatar
Yes you CAN but it is a total PITA.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 05-23-2013, 01:10 AM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
Here's mine. Oh wait...sorry that's my plastic djm bracket. Weld on perches now works great.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-23-2013, 05:26 AM   #8
Oleblu1
Thanks, well I suppose I have some work to do. Thanks another question sorry to bother but the motor stuff is very new to me, is a timing chain dummy proof, lol. ?
Old 05-23-2013, 09:17 AM   #9
1981Stepside
1981Stepside's Avatar
Timing chain replacement is almost dummy proof. Just make sure the #1 cylinder is at top dead center (highest point on the compression stroke) to ensure the timing marks are lined up. Replace the gear in the same orientation that they came off, and make sure that the crank and/or cam do not turn when the chain is off. That will make for a very unhappy engine.
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 05-23-2013, 10:42 AM   #10
SkinnyG
SkinnyG's Avatar
This is the one I fabricated out of 1/2" flat bar for the flip, and 3/16" flat for the shock extenders. The 1/2" is too thick, so a cove is cut to saddle the axle tube - should stop the axle from shifting the DJM one did above. Not sure on the drop as I didn't measure before, and the box isn't on yet.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 05-23-2013, 01:56 PM   #11
bohmankid
bohmankid's Avatar
Do any of you guys have problems with the frame hitting the axle? I know most of you just take off your bump stops. Would putting air bags in the back help with the ride?
bohmankid is offline   Reply With Quote
Old 05-23-2013, 03:45 PM   #12
Oleblu1
How is the angle as far as the rear end with this method? any shimming involved? or does the angle not change?
