Resident of Here
3500HD Dana 80
Anybody know more about these? It's 10 lug with huge discs. The tubes are 4"-4.5" 4:56 tag. Casting says 80HD and 037453. Are they worth anything? Can you swap hubs from a dodge D80 to get 8 lug?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Re: 3500HD Dana 80
I want to say you can. Over on pirate there was a talk bout these, and thought I read that the outer bearings were Dana 70.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
I built it
Re: 3500HD Dana 80
i THINK thats only on the dodge dana 80. the real dana 80 (like pictured) was a 10 lug. dodge had what they called a "hybrid" dana 80. d80 pumpkin and dana 70 outers. as for if it swaps out, i have no idea...
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
Re: 3500HD Dana 80
Like said above the Dodge D80 uses all D70 parts other than the pumpkin. You can actually see where axle tubes are necked down. I wouldn't waste my time or money on that axle. Either find a Dodge D80 or just go with a med duty truck axle if you need the strength. Dana/Spicer S-110 axles have alot of gear ratio options and came with juice brakes. Not to mention a 500k oil change interval!
![]() Join Date: Jan 2007
Re: 3500HD Dana 80
If it's cheap and you can get it to fit...why not.
Having to set up the gears/etc may be the expensive part.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
Re: 3500HD Dana 80
10 lug rims.
Re: 3500HD Dana 80
Bringing this back to life... I'm in a similar situation. I was given a Dana 80 10 lug from a 90's Chevy cab/chassis. Gonna rebuild it so changing out parts is totally cool as its gonna be totally rebuilt... but its 10 lug and my '86 3500 dually has the 8 lugs (and I had just bought 6 new tires so i'm not gonna buy new tires and rims).
My understanding is a Dana 80 is a Dana 80... Chevy/Dodge/Ford... its still a Dana 80. So the parts should interchange fairly easily (even if I have to change axles and differential, cause I'm going to anyways). How do I get it to an 8 lug? Does anyone have part #'s or year/make/model to reference? Its a disc brake Dana 80 and I wanna keep it that way, the rest of the parts (axles (splines), differential, etc... can go) as long as I end up with a 8 lug disc brake setup. Thanks y'all! -Chris
1966 Dorsett Daytona - 16'6" Fiberglass boat "Suits Us" 1972 Chevrolet P30 Motorhome - "Giddy Up Go" 1986 GMC C3500 High Sierra Custom - "Ruby" 2007 Chevrolet Avalanche - "Faith" |
Re: 3500HD Dana 80
Go to : www.3500HD.com
It's not a very large forum , but you may find more info. There are differences btw Chevy Ford and Dodge versions, 35 and 37 spline axles are one.
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 |
