Old 05-25-2013, 01:12 PM   #1
MattPSU
MattPSU's Avatar
Is this a valve cover issue?
I drove my truck (other than around the block) for the first time since I had it apart this fall. When I came back I checked the fluids and I noticed that my freshly repainted intake had stains on both sides. Is this just loose/not sealing valve covers or do I have a worse problem here?
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 05-25-2013, 01:17 PM   #2
modernbeat
modernbeat's Avatar
Re: Is this a valve cover issue?
That is heat staining from the heat riser. It's a port in the manifold that goes into the exhaust port either to heat the manifold, or on some older manifolds, to actuate the choke.
modernbeat is offline   Reply With Quote
Old 05-25-2013, 01:26 PM   #3
Roninwolf
Roninwolf's Avatar
x2
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=531265
72 Cheyenne Super
90 Z71 S.B. 434 C.I. Stroker
78 Camaro Z28 (gave to wife she is restoring it)
Roninwolf is offline   Reply With Quote
Old 05-25-2013, 02:04 PM   #4
MattPSU
MattPSU's Avatar
Thanks guys. So no problem? Nothing I need to fix? Just live with the stain till my budget allows for an aluminum intake?
Old 05-25-2013, 02:16 PM   #5
Rufton
I blocked the heat riser on one car; helps keep carb slightly cooler. MPG still ok. Cold weather performance still ok.
Rufton is offline   Reply With Quote
Old 05-25-2013, 02:23 PM   #6
66skylarkpost
66skylarkpost's Avatar
it appears that u are running full time vacumn to ur distributor .... it should be only going to the ported vac fitting in the front left of a quad that u have capped off ...
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 05-25-2013, 02:48 PM   #7
MattPSU
MattPSU's Avatar
Thanks for the heads up. This is how the carb was set up when I bought the truck, and my knowledge in this area isn't great. So I want to run it to where I have the red circle in the picture below???
Old 05-25-2013, 02:31 PM   #8
Rufton
Pros and cons to running full time vacuum.
Ask 2 people get 2 different answers.
Sometimes easier to just try it both ways.
Old 05-26-2013, 02:21 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yup... some do it, some don't. I've done it both ways as well.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-25-2013, 03:19 PM   #10
Square_78
Square_78's Avatar
Did you use high heat engine paint on your intake or just normal paint? If its just normal paint then they whole thing may turn that brown color as the paint cooks from the engine heat.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 05-25-2013, 04:01 PM   #11
MattPSU
MattPSU's Avatar
It's supposed to be high heat paint. I bought it just for painting the intake. Obviously it sucks that it discolored, but I'm more concerned about there being an issue. I can live with the stain (for now) but if there's something I need to do to keep it cooler, I want to take care of that first.
- Matt
Old 05-25-2013, 04:14 PM   #12
WIDESIDE72
WIDESIDE72's Avatar
As mentioned above, its from the heat riser. There are some little rectangular pieces of metal in your intake gasket set that go over the heat riser he in the head to block the heat from going into the intake. You will give up a little "drivability" when the enhine is cold, but it should solve the issue.
WIDESIDE72 is offline   Reply With Quote
Old 05-26-2013, 02:16 PM   #13
MattPSU
MattPSU's Avatar
These???
Old 05-26-2013, 09:04 PM   #14
WIDESIDE72
WIDESIDE72's Avatar
Originally Posted by MattPSU View Post
These???
Yep
Old 05-26-2013, 09:32 PM   #15
asolde
asolde's Avatar
I have the same issue with my intake painted Chevy orange. But felpro gasket instructions did not call for the block off set on my 69 350 so I left them out. I am concerned about too much heat under the carburator. I do not run a insulator spacer either. So far it seems to run ok.
asolde is offline   Reply With Quote
Old 05-25-2013, 04:16 PM   #16
WIDESIDE72
WIDESIDE72's Avatar
I block them off on all of mine, but then i live in Texas, where it hardly ever gets below 20'a and if it does het that cold, we get ice too, so my old stuff is not leaving the place anyway.
Old 05-25-2013, 04:34 PM   #17
66skylarkpost
here's is the port for timing advance . where u cirlcled is where the vacumn line for the door in the original air cleaner snorkel went
