Old 05-25-2013, 06:14 PM   #1
ozarks hunter
Jumpy fuel gauge
How much movement is normal of the needle when driving? My 71's is all over the place from the gas sloshing around in the tank. The guy I bought it from said when it stops moving it's about out. Even with the truck just sitting I can shake it and the needle moves like crazy.
ozarks hunter is offline   Reply With Quote
Old 05-25-2013, 06:31 PM   #2
ole dollor
ole dollor's Avatar
Re: Jumpy fuel gauge
it sounds to me like you may have a bad connection some where. might look at the wire and see if its trying to seperate, or has a brake in it, and check the wire at the sending unit and see if its clean and making good contact, i have seen the wires along the floor get corroded and turn green inside the insulation , from water and dirt and old wires. they also make a gage repair kit that might help if everything shows good...
ole dollor is offline   Reply With Quote
