Old 06-25-2003, 08:32 PM   #1
FrankHoy
FrankHoy's Avatar
Question Shift indicator lens
Does anyone know where a person can get a shift indicator lens for a 72 tilt column with markings to convert for a 700R4 OD trans? I know I have saw one before, when I was considering the conversion but hadn't made up my mind. I have looked at most of the board members' sites, that are vendors, and have not found one yet.
FrankHoy is offline   Reply With Quote
Old 06-25-2003, 09:36 PM   #2
Don Smith
Go to www.ididitinc.com look under steering accessories, cost is 20.00. You will have to a little sanding to get a perfect fit but it looks good installed and indicator lines up with correct gear using factory shift linkage
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
