Formerly yellow72custom
Sunpro guages?
Last year i modified the dash of my truck to accept a aftermarket tach, oil pressure guage, coolant temp. guage, and amp guage. I used a Sunpro tach, which i like so far, but i used some el-cheapo Euqus guages, and 1 of them stopped working, and the 1 other dosen't work all that great. So, i plan to get another dash from the salvage yard tomorrow, and modify it to accept new guages.
I was looking at Autozone, and they have a kit of Sunpro guages, with a volt, oil, and water guage for $32. My Sunpro tach has held up fine for more than a year, but are their other guages as good? I want something that will last for at least 5-10 years, not the 12 months of the cheap ones i have now. Also, which is better to have, and amp guage or a volt guage?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
i bought a temp guage by sunpro and its starting to crap out on me after a month or so. it won't give me a reading for a good ten minutes after startup.
SLOW BUT SURE,BUT CLOSER
I think Longhornmail used em' in his, looked great. I got a set of black faced Stewart-Warner I'd sell, they would look good in a stock panel.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
its all about the +6 inches
I have used them for yers with absolutly no problems what so ever.
Volts is a better guage to know whats up under the hood, they are easier to wire, and safer too. (all the vehicle's power goes through an amp guage...not so with volts) |
![]() Join Date: Mar 2001
I too have had good luck with Sunpro gauges...I installed a set
in an 86 mustang that held up for approx 15yrs...what did them in (at least on the electrical gauge) was the sun, the heat bent the needles into the face of the gauge, then they would stick. I also like the VDO gauge line...But I prefer mechanical type gauges over electrical....and here is why: Say your gauge starts to show low oil pressure, then you start to wonder if the gauge is bad, the sending unit is bad, or even worse, are you actually losing oil pressure and still have to hook up a mechanical gauge anyway. Electrical type gauges are the easiest to hook up, but once done, mechanical (oil press / water temp) a bit more faith can be had with them. I too agree, a volt meter is a better choice than an amp meter...esp with todays hi-output, hi amperage alternators can really over do an amp meter, a short circuit in this size wire would be dangerous. This is just my 2cents worth.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
I have autometer guages, which are obviously more than sunpro, but I think it's one of those things..ya get what ya pay for.
68cst_ss490
I picked myself up Autometer Phantoms fo rm y 68. I'm going to use the custom billet panel from brothers. I got a 5" tach, 5" speedo and 4 2 5/8 oil press, gas guage, temp, and volt. I will need one more, but not sure if I'm gonna use a clock or vacuum guage
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
My daily driver has all full sweep sunpros. On the bottom are amps, water temp, volts, oil psi. I put a smaller tach in the factory tach hole in the top middle. It fit quite well. The gas/mph are factory. They are black faced and i think they look pretty cool, wish wifey would buy me a digi cam :/
Now the others dig........
![]() Join Date: May 2002
eqqus has worked for me no problem....I bought them cause they were all black. they were pretty accurate....and let me know when my engine was about to quit on me on that sad trip home a few months back
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
I have no problems with my set-up.
www.surpluscenter.com has the Sun black and chrome oil psi gauge for $6.99. I bought a couple for my tractors. They have some other cheap gauges as well, but not enough to piece together a matching set.
Since we are pimpin inst cluster pics...here is mine. I still need a white tach, and i think I'll be putting a tranny temp guage in the dead hole....some day.
Nothing fits but the oil
I have the sunpro set-up and here is where I put mine. I've had no problems with them since the install last year.
Land of the free Because of the brave |
Hammer On!
![]() Join Date: Jul 2001
I heard stewart warner were very good gauges. I also heard you pay a quite a bit more for them than you would say..... equus or sunpro. We have a catalog of from that company at Oreilly's. They have some pretty sweet gauges but i don't think i could justify putting them in my beast. Just my .02 worth
![]() Aaron ![]()
1968 C20 Inline 6 250 SM465 4 speed 1968 K10 Inline 6 250 SM465 4 speed |
#15 |
I've been meaning to ask...on the billet
dash pads...how do they fit to the dash? As you know the dash has 2 humps formed into it for the light switch and wiper switch. Are they pressed to fit over these humps? The ones I've seen are just flat panels with the holes for the guages. Seems to me that this would leave a space on the edge. The original dahes have enough depth to cover these humps. Jim M. Mt Juliet ![]() |
#16 |
Thanks for all the info!
My current dash setup is the same as racedvl's and longhornmail's. I even have my tach in the middle, lol. The problem with the euqus guages is mainly the water temp guages. On the first water temp guage i had, it somehow shorted out in the backlighting, and caused the ether filled sending unitl line to rupture ![]() I think i am just going to buy a new dash bezel and put it on my current cluster, so i don't have to hack up another original cluster. I also need to replace my speedometer while i am at it. Where is the cheapest place to get a new bezel? GMC Paul and Classic Heartbeat have them for about $50...
#17 |
Check all the vendors on the main page. ( www.67-72chevytrucks.net) and look for sales. I bought 2 last winter on sale at 25 bucks each.
#18 |
Cool...i just ordered one from Rick's Pickup parts for $25. Half the price of the other vendors
#19 |
Same guy...maybe I'll get one for myself this time.
The fit is not 100% perfect, but you should be able to make it work, I did twice. |
#20 |
Geez Longhorn, great minds must think alike eh?
#21 |
auto gage made by auto meter
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
#22 |
special 70.... that looks good, keeping with the original black and white. it dont look out of place. you say autometer has a model called autogauge?
I'm not a Muleskinner...... Dad gave me that CB handle when I was 8 so......... it pops in my head every now and then. ![]() ![]() |
#23 | |
Bloo
kinda hard to see, but thats sunpros along the bottem of mine.,.. been there about 2 years now and the only problems i get are in my wiring harness
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
#24 |
hey bloo...I like the radio duct taped to the dash!
#25 |
Bloo
maybe i should also mention that pic is about 2 years old and its no longer tied to the top of the dash
![]() right now everythign is outta the dash, the bondo around the CB started cracking so i had to do some work** (**Disclaimer: thats not the original dash, i bought that one from a friend who had bondoed the ashtray hole smooth and i cut it out big enough for my CB to fit) |
