Old 05-28-2013, 04:20 PM   #1
BK'66Step
BK'66Step's Avatar
Any suggestions?? Steering box issue...
So as I was taking apart the front end and getting the frame prepped for paint, I took off the steering box and stumbled upon this... The rear-most bolt hole in the frame has been completely sheared out!! Not really sure what the best course of action would be at this point. I plan on putting in power steering but I'm not sure if that requires a special bracket that would require different hole locations. I thought about just hammering it flush and welding it the hole shut and then drilling a new hole, but I'm not sure that would be strong enough for the application... any insight would be much appreciated!! :-)
BK'66Step is offline   Reply With Quote
Old 05-28-2013, 04:46 PM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: Any suggestions?? Steering box issue...
I would stop-drill the crack and re-weld it. After that, I would convert the truck to power steering, and use one of Capt Fab's adaptor brackets and have it fully welded in. You'll be good to go after that.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-28-2013, 04:48 PM   #3
billd5string
billd5string's Avatar
I'd hammer it back, weld it up, and then get the adaptor plate from Captain Fab for a power steering box. Any power steering conversion requires new holes anyway, and you can weld the adaptor plate right onto the frame.
I just got done updating mine to power steering, and the plate and instructions from Captain were excellent - I highly recommend it.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 05-28-2013, 04:49 PM   #4
billd5string
Cool - chevyrestoguy had the exact same thought I did.
Old 05-28-2013, 05:02 PM   #5
BK'66Step
BK'66Step's Avatar
Thanks guys. I had heard of Captain Fabs adapter plate but I just wasn't sure of the bolt hole locations. Looks like I'll be in touch with him shortly!!
Old 05-28-2013, 05:05 PM   #6
BK'66Step
BK'66Step's Avatar
And stop drilling the cracks is a great idea! I wouldn't have thought to do that, but I definitely don't want that thing spreading down the road!!
Old 05-28-2013, 05:56 PM   #7
Vernski
IF you weld in the captains plate you should have -0- problems. That sounds funny doesn't it [the captains plate]...Vernski
Vernski is offline   Reply With Quote
Old 05-28-2013, 06:29 PM   #8
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Yep! What they said above!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
