Old 05-29-2013, 01:46 AM   #1
bambuhiphop
62 rear suspension options
Hello All,
I have been reading and reading and seemed to have confused myself more than when I started
What are my options for upgrading the rear suspension in a 62?
I have looked at maintaining stock with new parts, upgrading only the axle to a 12 bolt, or even a 4 link (both parallel and triangulated)...
I would like some more modern performance out of the rear as the front will be out of a 73 but it is still a truck and I do still on planning to haul stuff. Also, not looking to bag it and will only be doing a mild drop.
If someone could chime in or point me in the direction to do further reading I would much appreciate it!
bambuhiphop is offline   Reply With Quote
Old 05-29-2013, 06:17 AM   #2
C-10cutty
C-10cutty's Avatar
Re: 62 rear suspension options
If by "modern performance" you mean faster, then there a gears for the rear so you can cruise at highway speed. If you still plan on hauling stuff then I'd stick with the stock springs. I'm running Jeep springs for a drop but I don't haul anything with it. Many vendors sell drop springs but I'd don't know the load limit on them.
C-10cutty is offline   Reply With Quote
Old 05-29-2013, 01:28 PM   #3
bambuhiphop
I don't mean just faster when I say modern. I am also looking for better handling, ride improvements, cornering, parts availability, etc...
I actually like the 3.9's I have in there right now with the Overdrive.
Old 05-29-2013, 04:22 PM   #4
LVPhotos
LVPhotos's Avatar
Bags are not just for lowering, think as an adjustable spring on the fly. Trailing arms are very good platform, NASCAR used them as well.
A 12 bolt is strong a 10 bolt is still 1/2 ton. I run a 1970 12-bolt 3.73 posi with a 295/45/18 rear tire(28").
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
