05-30-2013, 12:50 AM | #1 |
Electrical
My 67 c10 won't start. Not even a click. Checked all the wiring, fuse box, battery, starter solinoid. As if the truck has no life or electric
Posted via Mobile Device |
05-30-2013, 12:52 AM | #2 |
Junior Member
Re: Electrical
Maybe there is a problem with the fuseable link.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
05-30-2013, 12:53 AM | #3 |
Re: Electrical
Thank you I will try that
05-30-2013, 08:44 AM | #4 |
Re: Electrical
auto tranny check neutral safty switch
rather than lookin at wires remove battery cables clean them then reassemble
05-30-2013, 02:14 PM | #5 |
Re: Electrical
I was driving at 35 mph the truck just died . We have checked everything. Put new batt cables on. Checked the tumbler switch for voltage that was ok. Tested the starter wasn't great but it should not be the problem.
05-30-2013, 02:27 PM | #6 |
Active Member
Re: Electrical
Post what engine you have and whether it's HEI or coil and points, manual or automatic.
Also, do you even get lights? Horn? If it just died while driving and you have an HEI could be the coil or module. Should at least be able to crank it though. If it's coil and points, could be the coil and/or points. Again, should be able to at least crank the engine. I would suspect the alternator and/or battery.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
05-30-2013, 02:21 PM | #7 |
Re: Electrical
x2!!!!!
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
06-01-2013, 07:57 AM | #8 |
Junior Member
Re: Electrical
Do you have power to the fuse block? There are some areas on the fuse block that have power even with the ignition switch off.
If there isn't any power to the fuse block there is a bad connection somewhere or the fuseable link is shot. Have you tried jumping the starter?
06-01-2013, 07:42 PM | #9 |
Re: Electrical
It is a 350 with HEI
06-02-2013, 01:26 PM | #10 |
Re: Electrical
Sounds like the fusible link, or the ignition switch. Check the power to switch. As was before mentioned, check fuse block for power. Most likely fusible link.
Good luck
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
