05-31-2013, 05:16 PM | #1 |
new bagged 79 swb project
Got this in a trade deal couple weeks ago, decided to drive it for a few days and figure out what i wanted to change.
the short list of change......almost EVERYTHING. my "plan" is to have a very clean driver, few subtle custom touches to clean things up... nothing too exotic besides stance and wheels on the outside. right now the 350 is staying, a 700r4 is goin behind that... eventually an ls motor will find its way in place. the interior is where the big changes will take place... but more on that one later.... first things first.... needed to get it down to a more respectable altitude... also wanted to center up the front wheel and hopefully gain clearance to keep the stock ac box with the new 22's frameZ.. 3" up, 1.75" forward back on the ground to see what else needs done... frame rails are now 5/8" off the ground... BUT i havent touched the rear yet bag mounts yet... the diff still has 3" till it hits the existing notch layed out and with the stock rollers... i have 1/4" to the blower motor and here is a lil teaser for the interior plan.... not the typical impala swap |
05-31-2013, 05:19 PM | #2 |
Re: new bagged 79 swb project
cool build man. Will you be keeping the stock clip up front? Looks nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
05-31-2013, 05:25 PM | #3 |
im keeping the 79 clip... everything will be going back to chrome vs the rattlecan black. im thinkin its gonna get a back bumper too. i think the only things gettin shaved will be the emblems, stake pockets, and gate handle. the gas filler door will access for air and battery.
05-31-2013, 06:38 PM | #4 |
nice truck....I'm likin' the dash...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
05-31-2013, 07:48 PM | #5 |
Cool man. I was hoping you would be keeping it.
05-31-2013, 09:44 PM | #6 |
the ups truck showed up... now i can figure out the next step since im not guessing on where the tires are gonna be.
im happy with the front wheel relocation... and the rear too |
06-02-2013, 08:03 PM | #7 |
one of the major things i didnt like were these cupped lower arms... they pinched the bag AND rubbed the bags prettymuch all the time. they will give up the cross shafts and the bj area cuz im just bein lazy vs machining them
maybe i will have this pile of stuff tacked together by the end of the day... still need to disect the old arms and clean stuff up... they work out to be a 2" drop and correct all the bag angles at ride height... made out of 1 5/8 .120 dom, the bushing sleaves were just some stuff laying around that was close enough for a finish machine pass... they will be plated on the bottom with P/O .200 plate |
06-04-2013, 09:54 PM | #8 |
finally got a lil time today... got a decent start on my lower arms...
besides the cross shaft... this little section is all i used from the old arms |
06-05-2013, 07:55 PM | #9 |
6>8 Plugless........
What's up dude? I see you're still alive and doing bad azz work as usual!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
06-05-2013, 10:18 PM | #10 |
still around... pretty much only working on my own stuff if i can help it these days.
06-05-2013, 10:58 PM | #11 |
Have any cabs left?
06-05-2013, 11:05 PM | #12 |
i could prob scrounge up somethin.... i am toyin with idea of doin a TT dmax in this.... you prob got somethin just layin around since its not your brand
06-05-2013, 11:10 PM | #13 |
Sorry man, no dmax stuff layin around here. 72duraburb does though.
06-05-2013, 11:29 PM | #14 |
im just toying with idea.... i can do a whole lotta ls motor for the money to do a dmax
06-06-2013, 02:32 PM | #15 |
Yes you sure can.
06-07-2013, 05:03 AM | #16 |
no kid or gf tonight, so i managed to almost wrap up my lowers... hopefully i can get them test fit and get started on my new uppers my next "shop day"
a little heat n beat fitting lower plates on couple more parts to fit and these are done notice the rolled tube brace... you can see what i have in mind for the uppers. i really plan to keep the uppers pretty simple, i kinda got carried away on the lowers |
06-09-2013, 03:32 AM | #17 |
after some shock mounting bungs and future way to mount a sway bar.... lower arms are 99% finished... need to mount them and mark for the bag mounting... then give em to my neighbor the powder coater once i get the uppers made.
think I figured out the color choice.... lets just say its probably gonna be an aquired taste for most |
06-09-2013, 09:19 AM | #18 |
It followed me home?
great looking work!!!!
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
06-09-2013, 05:03 PM | #19 |
pretty sweet arms....
06-16-2013, 09:23 PM | #20 |
finally got some more time to work on my upper arms. made these 3/4 longer than stock since the truck had 1" of alignment shims on top of the spacers... wasnt much thread stickin out the lock nuts.
where the truck sat before was binding on the upper bj, so I came up with the mounting angle by just mocking everything up with my dropped arms, bag compressed all the way and went back just before the upper bj binds. keep in mind i still have stock spindles on the truck, and I wanted to make sure it lays frame now...so should i decide to go bigger rollers, drop spindles are all that will be needed to keep it laying frame. pix... more later tonight if i get around to mocking everything up all the fabbed up parts layed out.. setting up a quicky jig the difference in bj angle compared to stock... they are also 3/4" longer tacked together... ready to take out bushings and weld solid |
06-17-2013, 11:44 PM | #21 |
visited the nieghbor this morning, came up with a met graphite color for my arms...
assembled and ready for install.. arm angles frame flat on ground.. frame just touching ground... this is point where bags are compressed all the way, so i will be able to throw some shims in to fine tune the ride height. next major step will be a body drop... not tradional, not exactly stock floor either... just have to check back |
06-18-2013, 05:13 AM | #22 | |
soooo im just gonna stock floor it, lay the pinch welds and be able to turn... problem solved.... i see lots of overhead welding plans for next weekend btw... these arms at RH managed -.25* camber, and +6* caster with no shims at all....almost like i planned it. |
06-18-2013, 02:15 AM | #23 |
Diggin The SquareLife
badass!!!!! I want some of them arms!!!!! lol!
06-18-2013, 07:30 AM | #24 |
Great build, waiting to see the dash.....
Tim Posted via Mobile Device |
06-20-2013, 06:00 PM | #25 |
Home Built '87
Looks really good
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
