![]() Join Date: Apr 2005
I'm changing the oil pan/pick-up tube on my 6.2 2013 Camaro SS engine to a 2007 Cadillac CTSV oil pan/pick-up tube. The Camaro pick-up tube has a RED o-ring and the Cadillac pick-up tube has a BLUE o-ring. I tried them both and they both fit, but the red O-ring "seems" to fit better. I need to make sure I have the correct one in there because I don't want to have to change it out after I install the engine (or even worse damage the engine). Any suggestion would be helpful. TIA.
EDIT: the 6.2 was a AFM/VVT engine but I deleted both of those internally. The CTSV pan does not have the oil bypass like the Camaro pan does. Not sure if this makes a difference, but like I said I don't want to have to do this again.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
meowMEOWmeowMEOW
Re: Which o-ring to use, RED or BLUE?
I always used the o-ring that came with the pickup, not with the engine.
I had the black and blue o-rings when I switched to the LH8 pan; I used the one that came with it, despite the fact that they even Mic'd out the same.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#3 | |
#4 | |
meowMEOWmeowMEOW
When I used the Ctsv pan on my conversion it was blue for me. I think there was a gm bulitin that changed from red to blue
Posted via Mobile Device |
#6 | |
O K, use the Blue O ring is that the 12584922 ?
What about the pan gasket anything "special" about the gasket for a 2003 5.3 Rob any surprises a year later?
Nope. Good to go.
