Sway Bar Bushing Clamps
Re: Sway Bar Bushing Clamps
Aftermarket bushings come w/the brackets. Prob won't find many left on dealership shelves but salvage yards usually have them.
#3 | |
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
That picture is one of mine. The part number written on the cardboard is still a viable GM number. My dealership keeps them in stock. Just walk in and tell them how many you want.
Hey TX Firefighter! it is your picture from you how to install sway bar thread. good write up btw helps out alot.
i did get sway at junk yard but wasnt able to get two clamps. think i might just go back and get clamps at the yard cuz the closest dealer with them in stock is further than the yard. thanks for the replies guys. |
#6 | |
How does that improve it? I read it somewhere else but I don't get how it works. Is it something you can't explain and just know it works?
Posted via Mobile Device |
OE rubber bushings have a lot of excess material which allows movement/flex from deflection. Poly bushings deflect much less. When used in the frame position they allow the sway bar to pivot up/down w/o deflecting. Think of it like a 35 series Z rated tire on a Vette to a 75 series tire on a van. Shorter, stiffer rubber offers better (more precise) control of what ever it contains. Using the OE brackets w/aftermarket (parts store) bushings @ the control arms offer better control vs factory rubber w/o the binding associated when using poly in this position.
Thanks for explaining that for me. Maybe later I will I already had bushings.
I ended up going back to the junk yard for the brackets ha ha ha thanks guys. Posted via Mobile Device |
