06-02-2013, 08:53 PM | #1 |
Which POR15 is right for my frame ?
I see all these kits an such for POR15 and i want to do my entire frame so what "kit" do i need to get or do i just need to order everything seperate ?
06-03-2013, 03:46 AM | #2 |
Re: Which POR15 is right for my frame ?
There is a kit on ebay with the metal prep, marine clean, and por15 all in gallon size for $160. Doubt you'll need a gallon but thats what I got just incase I find that I need it for other needs.
06-03-2013, 12:38 PM | #3 |
Remember that POR-15 has no UV protection and must be top coated when exposed to sunlight. Also once you have opened the can put a piece of plastic bag over the can before closing or you will not get the top off again. It sticks much better to a lightly rusted or sand blasted surface, it doesn't stick well to smooth or shiny surfaces. Good stuff when correctly used.
06-03-2013, 12:47 PM | #4 |
This is what I used
Posted via Mobile Device Posted via Mobile Device |
06-03-2013, 12:48 PM | #5 |
06-03-2013, 03:00 PM | #6 |
06-04-2013, 10:46 AM | #7 |
06-05-2013, 05:20 PM | #8 |
I used por 15 and Ive used chassis coat (silver)----I like the chassis coat better. Por 15 is good but the other sprays better and can be top coated with anything---por 15 cant.
The ad says its self leveling and can be brushed on-----but it never lays really flat if brushed.
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
06-05-2013, 08:05 PM | #9 |
Yup, i used chassis black, let fully dry and painted with gloss black
06-05-2013, 08:10 PM | #10 |
any advantage to this compared to powder coating other then cost? Im assuming pc'ing will be a better finish and more durable?
06-05-2013, 10:30 PM | #11 |
Moderator
Powder coating is not as durable as POR 15 or chassis coat. POR can also be topcoated with anything. It either has to be "tacky" and not fully cured, or an etching primer can be used if it is cured.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-05-2013, 10:43 PM | #12 |
I used it on some of my parts and frame and was happy with the results. I do have some advice...no matter how hard you try not to get it on you...you will. Fingernail polish remover (stolen from the wife) took it off. Good luck!!
1972 C10 CST LWB |
06-05-2013, 10:49 PM | #13 |
dont suppose any one can tell me how much ill need to do my whole frame ?
06-05-2013, 10:52 PM | #14 |
2 quarts should do it. I've done half my frame and some misc. parts and still have part of a quart left.
1972 C10 CST LWB |
06-05-2013, 10:54 PM | #15 |
Good deal Thank ya kindley ! did you brush or spray ?
06-05-2013, 10:58 PM | #16 |
I used foam brushes, just don't use the really cheap ones, get the good quality foam ones.
1972 C10 CST LWB |
