Blown 327
Here is the Dyno graph from the last pull on my blown 327. Air fuel is a little fat but better safe than sorry. Timing is set at 32 degrees all in by 2500 rpm's. Numbers seem a little low to me any suggestions would be helpful.
Registered Truck Offender
Re: Blown 327
What boost and cam?
Curious why you stopped at 5500? I don't know blower motors that well but 8.2 a/f and dropping seems like it's MAJOR fat not 'a bit'
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
Re: Blown 327
Boost gauge was showing 8 psi and the cam is a summit k1103. We stopped at 5500 cause doesn't really make any power after that.
It's Better With Nitro
Re: Blown 327
Did you have a target power range before starting your build? What type of supercharger (my apologies if it is posted somewhere else)? Did you select that cam as part of the complete blower combination, or were your top end components chosen in stages, and are you willing to change cams at this point? Also, is 8 psi of boost your goal, or were you looking for more? Just trying to get some clarity on your combo.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Re: Blown 327
The blower is a weiand 177 with a holley 750. Had a comp 292 in there at first went with the smaller cam to go with the stock converter and the 3.08 gears. Drive it daily was shooting for closer to 400 rwhp.
Posted via Mobile Device |
60-66 Nut
Re: Blown 327
I don't know that much about boosted engines, but that looks like a mismatch of parts. Heads with too big of intake ports for the cu in of engine. Too small of cam for power goal. Too big of carb for size of engine.
Is this an engine dyno, or a chassis dyno?
Re: Blown 327
Gotcha...based on this, I think the power band is right in line with what I would've expected. I select my cam more based on the cylinder heads and induction type as a combination. I then select my torque converter last based on the power band the final engine combo makes, and the chassis weight.
#8 | |
Re: Blown 327
Any detonation at all? Did you try backing off the timing and giving it more RPM?
1985 K10 Under Severe Reconstructive Surgery 5.3/New Paint/New Interior/Yadda Yadda Yadda Last edited by AJII; 06-04-2013 at 03:39 PM. |
Re: Blown 327
The air fuel doesn't get under 10 unless I am reading the graph wrong. I could lean out the secondaries a bit and shoot for 12 if that will help. What about the lean dip in the beginning?
Re: Blown 327
No detonation. Just hooked up my msd 6btm for the timing retard just to be safe. The cam is only rated to 5200 rpm. Also has aluminum heads with 195 intake runner 64cc combustion chamber with 1.6 roller rockers long tube headers and full 3 inch exhaust.
Re: Blown 327
That is at least HYD Roller Territory an high RPM with those heads an the small CI's.
Re: Blown 327
Yeah it's time for new specticles I guess. I couldnt see the img that well and it looked like the line it was hovering around was 8.2.. but but it's 12 (DUH!!)
#13 | |
My Carbon Footprint
Re: Blown 327
Re: Blown 327
Lean spike.. I am not the best carb tuner but from what I understand that could be an accelerator pump issue. Perhaps too small, but I'd have a few others comment before taking my word on that one.
AF... Sorry, but from the hit I think it is too rich and only getting worse. Some motors like more fuel and some don't. But we are talking less than .5 of AFR. My finding is most don't. I have seen some pretty big gains getting out of low 11/high 10 AFR and putting the motor where it likes it. Some like 12.6 some like 13. The old saying that "fat is safe" is being proven untrue more and more every day. What happens to the extra fuel in the cyl? Once it gets past the first ring in to the second, build enough heat and you could be lifting a ringland. I have watched a budy of mine tune carbs on a dyno and he does it similar to how I do EFI: Keep timing mild Get fuel curve right, IE get it flat fast and find where the motor makes most power. Then start adding timing back in at 2* increments until it does not make any more power. Then back it off 2-4 degrees. Less advance is always more safe than more fuel. I bet there is 40rwhp in that tune. But 100rwhp, probably not. The reason for going with a smaller cam would definately be justifiable if you were still NA, but being blown, it is probably hurting you. I personally don't think the heads runner size is an issue, being boosted will definately over come any short comings there. You are seeing 8lbs of boost? Did you double check with a boost gauge while making pulls? Posted via Mobile Device
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#15 |
Re: Blown 327
Am I the only one here that is of the belief bigger runners are not a big issue when there is positive manifold pressure? Under vacuum, I would absolutely agree that a smaller port that flows the same cfm is going to aid velocity and mid range tq. But when you have positive manifold pressure, you are forcing air in past the intake valve. In my opinion there is a major difference between the two.
#16 |
![]() Join Date: Jan 2011
Re: Blown 327
When I was playing with blown Mustangs I concentrated on the exhaust side because the intake will take care of itself when you're forcing it in there. A split profile cam with more lift and duration on the exhaust is good, keep the centerline more along 110-112 so you don't bleed off your boost, a blower will tame a cam so go bigger than you would for normally aspirated, port the snot out of the exhaust, big headers and pipes, 32 degrees timing is plenty, and I'd consider even more carb (minimum 750)and be sure to boost reference the power valve.
I had a 302 putting 437 horses and 413 torque at the rear weels with 13 pouds of boost, B&M 177 blower with a highly modded R3310 750 Holley, gauging on a risky T5 and was running 11.7 @127 mph with 3200 pound mustang full interior, boom box, and roll cage on nitto street radials p\s, p\b,cruise, tilt wheel, cold air, and getting 16-18 mpg doing it back and forth to the track. 6 inches daylight under the left front on launch... I was spraying a 75 shot in there under the carb straight into the blower, used that as an intercooler made things get really real then, picked up 5 tenths, nearly in the tens with a daily driver. Last edited by T Smith; 06-05-2013 at 09:53 PM. |
#17 |
Re: Blown 327
ignore my double post!
#18 |
Re: Blown 327
I'd have to agree with Blue Rat, T Smith, and Super73.
Of course this is my humble opinion, but, I definitely think you need more cam. Going larger does not mean you have to go into super high RPM. Look at the torque this thing is making, not bad at all! I don't think the heads are too big for the engine. Putting a supercharger on there makes the engine breath alot heavier, and mimicks a larger cubic inch engine. I'd also just build for the power you want to make, then look at stall, then gears, if you feel you need to.
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
#19 |
Re: Blown 327
LOL, 'lost' is a serious understatement sometimes
#20 |
My Carbon Footprint
Re: Blown 327
I am only 45 and have lost all my close up vision in the last year. I used to laugh when I would ask guys for a Holley list number off the choke horn and they would say "hang on.....let me get my glasses". I now have reading glasses all over the house, the shop, the car and my office. All down hill from here I think.
#21 | |
Re: Blown 327
#22 |
Re: Blown 327
yup,,, around 45 is when things 'start' going to all to hell. You don't want to hear what's next.
. . . . Actually . . . you WONT hear it is the point! LOL
#23 |
Re: Blown 327
Then I've got 3 months till it all goes to hell.
71 Chevy Stepside 377/350 |
#24 |
Re: Blown 327
Finally got the truck up to the track Friday night best run was a 14.5 at 96 mph
#25 |
Re: Blown 327
That's almost exactly what most performance calculators/dyno simulators predict in ET/MPH for your combo.
