Old 06-04-2013, 04:59 PM   #1
sodly
sodly's Avatar
66 hubcap ID
Can anyone tell me what this cap came from? I recently picked it up thinking it would work for my 16" Custom Camper 2 piece wheels. However, upon closer inspection it's clear that the ring on the back is different. I thought there were only two types of caps on these trucks.... the 1/2 ton cap without the inner back ring and the 3/4 ton cap with it. Apparently there are other variations.
Please compare the photos below. The correct cap for my 66 Custom Camper (on the left) has a back ring diameter of approx 9.25". This new cap's diameter is approx 8". The back ring is also much more "sunken", if that makes sense. It doesn't protrude as far from the back. It almost appears to be pushed down into the cap somewhat.
Anyone know what this thing fits? Anyone need one?
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 06-04-2013, 07:31 PM   #2
oem4me
Re: 66 hubcap ID
Your original obviously fits an eight lug 3/4 ton "clip" type wheel. I think the other flanged hubcap shown fits a six lug 1/2 ton clip wheel. Then there are the "nub" type wheels which take the flangeless hubcaps. Why so many sizes and ways to retain hubcaps I don't know. Factorystock here on the board seems to have it all sorted out though. Do a search for hubcap ID and read his posts. Good luck!
Old 06-04-2013, 09:05 PM   #3
rideblue00
rideblue00's Avatar
Re: 66 hubcap ID
Im not completely sure, but i thought it was for a 19" wheel
rideblue00 is offline   Reply With Quote
Old 06-04-2013, 09:12 PM   #4
yelmer
Re: 66 hubcap ID
Hello i have 19.5 wheels it takes the 8.75 for the cap . If that helps?
yelmer is offline   Reply With Quote
Old 06-04-2013, 09:18 PM   #5
sodly
sodly's Avatar
Re: 66 hubcap ID
Sounds like OEM4ME nailed it. I think my mystery cap is for an unknown-to-me-until-today 1/2 ton clip-style wheel (Thanks, Yelmer!). As stated above, sounds like all the 3/4 ton caps have an 8.75" flange opening (inner diameter)... which is approx. 9.25" outer diameter as the photo shows. Learn something new every day!
WANTED:
Old 06-05-2013, 10:02 AM   #6
60-66
60-66's Avatar
Re: 66 hubcap ID
Sodley, you CAN still use that cap. The ring inside can be removed and then put your old one in its place. I used a few of those small ring caps for the outer shell on my 3/4 ton 4x4. Takes a little time but could be worth the effort, start on your worst hubcap first though. Jon
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 06-05-2013, 11:45 AM   #7
rideblue00
rideblue00's Avatar
Re: 66 hubcap ID
Thats right i did the same thing for a set i have.
Old 06-05-2013, 11:54 AM   #8
sodly
sodly's Avatar
Re: 66 hubcap ID
Yep, thanks guys. That is a possibility.
WANTED:
Old 06-05-2013, 12:31 PM   #9
60-66
60-66's Avatar
Re: 66 hubcap ID
Old 06-05-2013, 01:06 PM   #10
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 66 hubcap ID
7 5/8 diameter fits 15-16 & 17.5 inch clip style wheel 6 on 5.5inch bolt pattern.
Old 06-05-2013, 11:15 PM   #11
factorystock
factorystock's Avatar
Re: 66 hubcap ID
Don't throw that 7.5" out! You can modify the 1/2 ton hubcap into a 3/4 ton hubcap with some work. The key is to buy some beat up rough looking painted 8 3/4" inner ring hubcaps for cheap. All you want is the back ring off them. You need to cut them off with a die grinder at the edge. Then JB weld the ring to your nice chrome 7.5" inner ring cap. Do this 4 times for 4 different hubcaps. THe 64 thru 66 1/2 ton and 3/4 ton hubcap has the same physical demensions, its only the back side that is different.
factorystock is offline   Reply With Quote
Old 06-06-2013, 09:31 AM   #12
sodly
sodly's Avatar
Re: 66 hubcap ID
Sounds sketchy, Factorystock. Have you done this? Would love to see pics. Not sure I'd trust JB Weld to hold my hubcaps on! Yikes!
WANTED:
Old 06-06-2013, 07:26 PM   #13
factorystock
Re: 66 hubcap ID
It works great, very solid with JB weld. You can also spot weld them in too, but I not sure if the chrome will be effected with the heat. Here is the ring that must be cut off the doner 3/4 ton cap. Then just attach to the 7.5" cap. It can even be done to new reproduction 10 1/4" hubcaps I guess, but I needed the painted caps which aren't reproduced.
Old 06-06-2013, 07:53 PM   #14
sodly
sodly's Avatar
Re: 66 hubcap ID
So are you prying up the lip of the new cap all the way around (like 60-66 did )and then gluing the new ring down on top of the existing (smaller) ring... and then folding the edge of the new cap back down over the new ring? Can't tell for sure in the photos. Thanks.
WANTED:
Old 06-06-2013, 08:02 PM   #15
60-66
60-66's Avatar
Re: 66 hubcap ID
On my 66 Gold truck all I did was remove the ring from each cap, insert the desired ring and tap the edge back in place, no glue no weld and all parts from either cap are still..................... "factory stock"
Old 06-06-2013, 10:02 PM   #16
factorystock
Re: 66 hubcap ID
No, I did not want to take the risk of damaging any metal on the good hubcap, just JB welded the ring directly to the back. Scaped off painted surface so the bond was clean metal to metal. Very difficult to tell it is not a genuine 3/4 ton cap when complete and has held up very well.
Old 06-06-2013, 10:56 PM   #17
sodly
sodly's Avatar
Re: 66 hubcap ID
Hey, Factorystock.... tried to PM you but it says your inbox is full.
WANTED:
Old 07-09-2013, 03:54 PM   #18
sodly
sodly's Avatar
Re: 66 hubcap ID
Did you ever clear out your inbox, Factorystock?
WANTED:
Old 07-18-2013, 08:58 PM   #19
rideblue00
rideblue00's Avatar
Re: 66 hubcap ID
I learned something today about hubcaps. I bought a set of caps from a fellow board member and got them today. He said that they were from a set of 17" 8 lug clip type wheels from his c20. They are the same as my 16" 8 lug clip type wheels from my c20. They are identical. They look just like the one on the left in sodly's first picture. They are 8 3/4" across the back. My wheels are the 66 split rims.
Old 07-19-2013, 04:40 AM   #20
Vernski
Re: 66 hubcap ID
Check this link out..Vernski
http://www.hubcaps.org/allgmc.html
Vernski is offline   Reply With Quote
