Air Compressor
Picked this up for $50.
Needs a little TLC but runs fine. "Made in the U.S.A." I've been wanting a larger one for years and got lucky with this find. Kim |
Re: Air Compressor
Kim, nice find !!
Re: Air Compressor
you'll wonder how you ever got along without it
![]() 9.5 cfm @ 100 psi is nice, i think mine is rated 10 cfm @ 80 psi it probably cuts down to 5 cfm @ 100 psi yours will pump up a lot quicker
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
![]() Join Date: Jul 2012
Re: Air Compressor
$50? Damn, I thought I did good picking up 5HP/60G for $200.
Re: Air Compressor
great find !!! good luck with it --$50 ? wow!!!!
Re: Air Compressor
That is sweet, I think it is a predecessor to this one or the rated below this one http://www.grainger.com/Grainger/SPE...E99?Pid=search
At any rate it was sold new at Grainger and you still should be able to order parts from Grainger.
#7 | |
Re: Air Compressor
I think it's an older model but will work just great in my garage. Kim |
Re: Air Compressor
Great find Kim
Whats good is you can buy relacement parts real easy. The compressor I bought the PO said it keep popping the house breaker, if by chance it blows a breaker check the copper tube that goes from pump to tank there is a valve at tank. It is easy to cahnge, this one way valve sometimes stick lube with WD40 or replace it is cheap enough. No more problems with mine after I did that.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
#9 | |
Re: Air Compressor
Kim |
![]() ![]() Join Date: Nov 2008
Re: Air Compressor
Wow! $50??!
I thought I did well finding a used 60 gallon Harbor Freight POS for $250 a year ago. |
#11 | |
Re: Air Compressor
If you to to the "local" air compressor shop they won't laugh at you when you ask for parts for it or want to have it worked on if needed.
Re: Air Compressor
Re: Air Compressor
Smoking deal...sure you weren't packing a gun when you made the deal with the previous owner?
