06-07-2013, 07:03 PM | #1 |
Tough trucks
What's an all around tougher truck for work/offroad/mud, not talking about comfort, the 81-87 Chevy or the 88-98 Chevy
Posted via Mobile Device |
06-07-2013, 08:15 PM | #2 |
Re: Tough trucks
Well, the squares are more simple and easy to fix. But the 88-98 style is a bit more powerful because most are injected and more balanced in the fuel system. Sometimes squares can be harder to find used parts for depending on where you live. They can also be difficult to find not worn down to the dirt. Which I prefer depends on the situation.
My names Tye. No Chevy right now |
06-07-2013, 09:30 PM | #3 |
Re: Tough trucks
Each definitely has it's pro's and con's. but if it's just a mudder i'd do the square's. easier to lift and last longer lifted. But if it'll be driven AT ALL on the street at all i'd do the 90's.
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
06-08-2013, 12:03 AM | #4 |
Re: Tough trucks
My choice for a tough 4x4 is solid axle,use one as a daily driver on pavement,gravel,dirt road & mud when needed.I got buddy's using IFS Chevys for same thing I am doing with my old truck& they get their front ends rebuilt lots!! Chevy quit making 4x4s when they went to IFS far as I am concerned....Sure maybe they might ride better,but hey it's a truck!! It's supposed to be firm!!
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
06-08-2013, 08:55 PM | #5 |
Re: Tough trucks
Thanks for the input everybody
06-08-2013, 09:31 PM | #6 |
Re: Tough trucks
Solid axle for sure. I run 80's Chevys for my plow trucks. Can't kill them. A IFS truck is usually done in 3 years of heavy plowing.
The best Chevy ever made would be a 1987 V30... EFI and a solid dana 60! |
06-11-2013, 09:21 PM | #7 |
Re: Tough trucks
shortened k30, xover, 37s with a ls swap.. best of all worlds.. jam 6 of your buddies in it, beat the snot out of it... perfect work horse.
* 1968 GMC Swb - 98% done (current restoration) * 1971 Chevy Lwb - Retired Dump Hauler * 1982 K10 Longbox - New Dump Hauler |
06-12-2013, 06:37 AM | #8 |
Re: Tough trucks
If you gotta have IFS and 4WD, go with a 1-ton. The half ton IFS is a joke.
06-12-2013, 09:29 AM | #9 |
Re: Tough trucks
I would put a sfa in a GMT-400 myself. As mentioned, newer and more powerful, stronger frames (let's be honest the square frame is a bit of a noodle off road, plus things like stewing box). K2500HD/3500 with Vortec 454 & NV-4500 aaaand GO, you already way ahead of a square.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
06-12-2013, 05:27 PM | #10 |
Re: Tough trucks
the 88-98 have the following problems when subjected to heavy use..ask me how I know.
Door Hinges crack and wear out Ball Joints wear like crazy Frames crack right behind the front cab mount The glued in rear windows like to fall out Inner door handles brake faster then you can replace them The NV3500 is a good street trans, but does not like being beat on The square bodies are simply better for being beat on because: Door hinges are bolt on Solid axles hold up better + they are cheaper and easier to lift Carbed engines are easier to work on in the middle of nowhere Better manual transmissions No Airbags No ABS But that is just my opinion from personal experience -Sam
1987 Chevy R30 CC 454/4spd Work Truck 1979 Chevy K10 SWB 350/4spd/NP205, 1979 Chevy C10 LWB 350/TH350 Project 1981 Chevy K30 350/Th400/NP205 1986 Chevy K30 CUCV 6.2L/TH400/NP208 |
06-12-2013, 06:03 PM | #11 | |
Re: Tough trucks
I agree with all of this... except the carb part! I like TBI it's about as reliable as you can get, and cheap to repair every once in a while if something happens. |
06-12-2013, 08:53 PM | #12 | |
Re: Tough trucks
The other problems associated with the 88-98s i've heard of but the cracking in the frames is more along with the square bodies around the steering box. |
06-12-2013, 09:07 PM | #13 |
Re: Tough trucks
I will get pictures of the cracks, on our 97.
You are right the square bodies do like to crack near the steering box, but if they are reinforced they are hard to crack. -Sam
06-12-2013, 09:12 PM | #14 |
Re: Tough trucks
best 4x4 to beat on u say? 1948 dodge piwer wagon 1 ton geared so low a sail is fast but u cant kill them.
now in the real world if it where me. any 72-91 1ton with a real diesel not a 6.2 i am talking cummins cat or detroit. with a clark 5 speed or the like. good luck killing that set up. and can be done alot cheaper then the ifs trucks Posted via Mobile Device
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
