Info needed from the Turbo 400 guys!
Could someone please post some pics showing the proper routing of the wire harness for the pedal mounted T400 kickdown switch? I did a search but didn't find anything.
Thanks! |
Re: Info needed from the Turbo 400 guys!
Beuller?? Anyone?
Ttt.. Anyone????
Posted via Mobile Device |
No one? Seriously?
Divorced .....WITH KIDS
Try the engine and drivetrain section . That may help .
1969 GMC SWB 1975 Chevy Malibu 80k 1963 Ford Galaxie 63k (inherited) 2005 Nissan Armada (wife's idea) |
The switch is on the gas pedal bracket for 71-72.. But where is the kick down switch on a 67-70? That's something I've been wanting to know for a long time
I believe the switch is mounted on the side of the carburetor. At least, that is what I concluded when I did research on how to hook it back up after putting an Edelbrock 1406 on it (I used a nitrous micro switch.)
I'm sure one of the fine posters here has more adequate info, but if there's no responses here I'll take a picture of the factory kickdown on the carb for ya. Posted via Mobile Device |
i have a th400 with the kick down switch but im pretty sure its supposed to attach to a bracket by the gas pedal. mine was "rigged" to work off the quadrajet. i switched to an edlebrock and couldnt get it to work, so i just tied it up. i have researched it before and im fairly cirtain its supposed to be on the gas pedal.
![]() USMC SEMPER FI 68 Chevy Longhorn 350/400 factory posi |
![]() Join Date: Feb 2004
Push button in cab on shift handle works cool.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#10 | |
i found this on google. its a bit of reading but it might have the answer your looking for.
http://www.google.com/imgres?imgurl=...ed=0CEYQrQMwDQ it looks like you just run one wire up to the the switch and a hot wire to the fuse block.
67chevy1series
if i understand right this is the older switch ![]() this is the 71-72 switch ![]()
Not what I am looking for but thanks anyway. I want to see the path the wire takes as it goes from the switch, through the cab, exits thru the firewall and connects to the tranny.
![]() Join Date: May 2007
The wire runs through the same hole/grommet as the oil pressure line, down through the firewall tabs, with the taillight wires, and on to the trans. Sorry, I don't have any pics. Hope this helps!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#15 |
Thank you Turp! Even without pics, this is the best answer yet.
#16 |
![]() Join Date: Jun 2008
Same here Turp! That was a BIG help! by the way, I like your picture... Hope you didn't get hurt and the truck survived too.
72junky
72junky Don't worry my wife said it's ok. '72 K10 custom/10 350/4spd,ps,pb,ac,tilt,tach,3:73 posi,buddy buckets - driver '72 Cheyenne/10 swb 355/th350,factory black, loaded and lowered - toy '72 Cheyenne/10 lwb, 350/th350,ps,pb,ac,tilt - current project build '72 K5 Blazer CST 350/th350,ps,pb,ac,tilt,tach,3:73 posi - project rust bucket -Unfortunately Sold plus 4 others too ashamed to post |
#17 |
Thanks! I wish it was a better pic. My left front tire wasn't to the top of the rock yet, so it actually went a little higher. My wife and kids were with me, and nobody made a peep! It felt like it was going to go over from the driver seat! It survived that rainy and slippery day, but over all, the rock crawling really took a toll on the old blazer.
