06-10-2013, 09:57 AM | #1 |
Trim hole locations ?
Does anyone have diagrams / measurement for all the trim hole locations ?
I have a 72 swb with all the trim, upper, lower side trim, tailgate trim with wide band, cab paint devider trim ( stud locations ) and badge locations for Cheyenne & 8-350. Any help would be great ! Thanks !!! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
06-10-2013, 10:48 AM | #2 |
Moderator
Re: Trim hole locations ?
Here are some:
http://outintheshop.com/faq/trim/trim.html The factory assembly manual has all of them and is a good investment. Posted via Mobile Device
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-10-2013, 12:47 PM | #3 |
Thanks.... Leddzepp !!!
Does anyone have the rest, or a assembly manual ?
06-11-2013, 02:27 PM | #4 | |
Still Learning
Does anyone have the emblem placement locations for the fenders? also, where is the dimension coming from on the vertical locations for the upper trim? is that from the top of the fender? 1.34"-1.23"1.16" etc,,,, |
06-11-2013, 12:03 AM | #5 |
PM sent. Re: paint divider trim.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
06-11-2013, 03:05 PM | #6 |
I just laid out my own trim, and if it comes out looking decent I'm going to start a thread with all my measurements and methods. I searched and searched on this site to find a step-by-step I couldn't find one, hopefully I can save people from the crap I went through.
Posted via Mobile Device |
06-11-2013, 04:16 PM | #7 |
Here's a link to the complete set of trim hole locations and an explanation of the 30" line that the upper trim locations reference: http://67-72chevytrucks.com/vboard/s...d.php?t=221881
When I added my trim to a non-trim 1970 truck, I based all of the upper trim locations off of the piece that goes on the door. With the cutout for the door lock, that was the only piece of trim that had a definite location, so I fit that piece first over the door lock and under my mirror arms and then located all of the other upper trim pieces off of that one. I used painter's tape to line them up until they looked good and then marked the holes. The spear points at the front were pretty easy because they come right off the door trim piece and point at the upper end of the radius on the fender around the headlights. Just watch the alignment of the upper bedside pieces because the alignment from the factory has them starting in line with the trim from the doors but angling down to meet the top corner of the taillight trim. If you tape everything up and then step back and compare it with some factory pics it's pretty easy to see if you're off anywhere. It's not too hard to get it all lined up. Good luck!
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
06-12-2013, 09:38 AM | #8 |
Thanks Curt, that's just what I needed.....
Thanks to everyone else that has helped out also !!! Gary
