Old 06-11-2013, 01:17 PM   #1
gharris79
gharris79's Avatar
1984 K5 Rebuild
Hey guy's i'm about to start to rebuild my 84 Blazer. I will be taking the 84 body off and i'm putting a 1990 rust free body on it that i got from North Carolina.
Does anyone know which year i should get the body mount kit for? I looked on LMC and can get the complete kits from them. They list them for 81-84 and 85-91. Is there a difference in the body or the frame mounts?
I've done this before but put a 1991 body on a 1987 frame without trouble.
Any input would be great.
87 Chevy 2wd
87 Olds Cutlass
09 Silverado
gharris79 is offline   Reply With Quote
Old 06-11-2013, 06:58 PM   #2
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Re: 1984 K5 Rebuild
Although there is not much of a difference between the 81-84 and 85-91 body mounts, I find it is always better to order kits that match the frame, when doing body swaps.
The tub mounting holes are the same 73-91, only the actual mounting shells and frame mounts changed.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 06-12-2013, 04:34 AM   #3
gharris79
gharris79's Avatar
Re: 1984 K5 Rebuild
That's what i thought. Thanks for the info.
87 Chevy 2wd
87 Olds Cutlass
09 Silverado
Old 06-13-2013, 04:47 AM   #4
gharris79
gharris79's Avatar
Re: 1984 K5 Rebuild
Here it is
87 Chevy 2wd
87 Olds Cutlass
09 Silverado
Old 06-14-2013, 01:50 PM   #5
SamsAutoParts73-87
Re: 1984 K5 Rebuild
Not a bad looking truck from here, but I'm guessing it has the normal floor pan and cab support rot.
-Sam
Old 06-18-2013, 05:06 AM   #6
gharris79
gharris79's Avatar
Re: 1984 K5 Rebuild
Only real bad part is the tailpan(tailgate support). I need to replace it and i expect to do some floor work there while doing that. Other then that the truck is pretty solid, it has some holes on the pass rear quarter where it had a tire carrier installed at one time. I'm going to another one after this is finished for my girl friend so this body will be fixed and used next year.
87 Chevy 2wd
87 Olds Cutlass
09 Silverado
