Help, I need to replace a leaky axle seal - never done it before
On my 86 2wd, fluid is seeping out on the rear passenger side.
I need to get it fixed soon - anyone have a good link for this? Thnx! |
Re: Help, I need to replace a leaky axle seal - never done it before
Are you sure it's not brake fluid leaking from the brake cylinder? It's easy to check. Pull the wheel off, then the brake drum. It should be pretty obvious if the the leak is coming from the the cylinder.
Actually you maybe right - because the brakes grab pretty hard on the opposite side it seems.
1/2 ton or 3/4 ton with floating axle?
It's a half ton, how do I tell floating axle?
It has leaf springs and shocks....that all I can tell ya... ![]() |
Probably has a 10 bolt which isnt a floating axel.
1979 ![]() 1996 Silverado x-cab "the daily" |
ok if it is a wheel seal. take tire and drum off then take diff cover off remove center pin for the alxe shafts and pull the axle out remove the seal and reasemble. not htat bad at all.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
#9 | |
I know the pieces fit
yea there is one of them to lol if the shoes are coated thro them the hell away i dont care how new they are. i have known some cheap asses and they soke in gas dry and reuse. witch i have done to.... for a few days till i get new( i live on an island parts are hard to get some times). i would also say do both when you do it
#11 | |
Half tempted to do a rear disc conversion. lol |
I did this same fix recently on a F*rd rear end, it's not that difficult. The hardest part for me was because I was determined to change the bearings while I was there, and pulling the bearings out was difficult, my slide hammer didn't do the job.
All the difficulty surrounding differentials is setting up the ring and pinion, and you shouldn't need to mess with that, so that's good news for you. Two possible pitfalls that can make this difficult. If it's a posi rear end, sometimes the spring can be difficult to install, I know mine was. Here are the basic steps: Like 86c20 said, take off the rear tire and drum. Remove the differential cover. Remove the differential center pin (also called the pinion pin). This can be one of the tricky parts because there is a set screw that holds it in, and the set screw is often broken. Sometimes you can fish it out with a pick ( I got lucky), otherwise it will have to be drilled out. If it DOES need to be drilled, there is a kit you can buy for like $30 and it is WELL worth it because it comes with a guide and a specialty drill bit. With the center pin out, remove the spider gears, and push the axle shaft towards the differential to expose the C-clip. Pull the c-clip and pull the axle shaft out. Now you have access to the seal. Pull the seal, replace, and installation is the reverse. Clean the differential cover really well and install a new gasket or new RTV.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
To familiarize yourself with the terminology and workings of a differential, you can buy a book or DVD that will show you how to rebuild them. You won't need ALL that information, because you won't actually be removing the carrier or messing with the ring and pinion, but it's not bad information to have. It will tell you all about the spider gears, pinion pin, c-clips, and how to deal with the springs inside a posi rear end (if you have one).
Looks like it's the axle seal. You can smell the gear oil and the entire drum and shoes are coated.
#15 |
good. if you do a disc swap let us know how and what you do. i want to do it on my 3/4 and 1 ton. but here so many things back and forth on it
#16 |
From what I can tell the one glaring issue is the handbrake. I'll need that, and the cheaper DIY conversion I seen doesn't retain it. In the end, she'll most likely just get new drums and shoes lol
#17 |
Moderator
![]() Join Date: Oct 2008
3/4 & 1ton 14bolt I'd use the Eldorado calipers. 1/2ton???
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#18 |
78K & 79C Jimmys
other owner had some welding done back there in my 88
lasted a while I put new offset bearings in
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#19 |
#20 |
Question - I just replaced the wheel seals a week or so ago, cleaned everything up very well, and tapped the new seals in squarely. I noticed that they started leaking again the next day when I went to finish up the brakes, so I left it sitting on the jacks in disgust lol. So, I'm getting ready to do the job AGAIN. I'm not sure what I did wrong, but this time I'll be applying RTV to the outer edge of the seal and a bit of bearing grease to the inside.
Any other tips so I don't have to do this again? |
#21 | |
My other suggestion would be the surface of the axle where the seal sits. Did you inspect that for pitting or wear? Double check the dimensions with a caliper to make sure you've got a proper match?
#22 |
#23 |
#24 |
I haven't done a set in quite a while (1990's ?), but I always make sure new seal is wet. Little smear of grease, oil, atf... depends on what I'm working on. No dry starts, new seals can be torn and/or burnt before the 90w can get to them.
Does the axle have a lot of slop moving it side to side?
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
#25 |
Thanks for the help, guys (OP - sorry to jack your thread). Everything looked smooth and appeared to be a good fit, but I will get calipers on them to be sure. I hadn't driven the truck since I put the new seals in, they started seeping while it was still sitting on jacks. I'll grease them this time, tho. Should have it all back together in the next few days.
