Old 06-16-2013, 11:52 AM   #1
bigtruckboi2000
bigtruckboi2000's Avatar
454block
Hey fellas,
I found this online and wanted some experienced/professional opinions about if its worth the chance on buying for a build later on. Here is the description posted-
Mark v 4 bolt main , 1 pc. rear seal , needs to be bored for new pistons. original crank broke causing no. 4 cylinder to be scorned , got a quote from local auto mach. shop to bore all cylinders for 104.00 , buyer must provide new pistons for mach. work . have all orig. pistons and connecting arms , assembled heads , cam , lifters , pushrods , oil pump , and pan , no intake or carb. included . previously listed for 500. so don't ask this is as low as i'll go this block has been cleaned and flushed
What u guys think?
[B][I]1965 Chevy C10 SWB w/350(68-79), 305 H.O Heads, Edelbrock Performer 1406 600 cfm carb, Torquer II Manifold, AC Delco HEI, TH400, Flowmasters,3.07 gears
2005 GMC Yukon XL Denali w/Mangnaflow Exhaust
1983 Cutlass Supreme w/ 350, cam, Holley 650 cfm, Street Dominator intake, carb spacer, hydromatic, Flowmasters
Patriots always talk of dying for their country but never of killing for their country.
bigtruckboi2000 is offline   Reply With Quote
Old 06-16-2013, 08:38 PM   #2
gofastnut
gofastnut's Avatar
Re: 454block
Gen, or Mark V is the "newer" block, starting in 1991 and going until ??
"Cylinder #4 scored" how bad? Are you gonna have to bore .030 over to clean it up, or will it require a sleeve in that hole? Unless the cam and lifters are New In Box. I'd ditch them and buy new.
What do you want to use it for? A base for a hot rod engine, or a mild built big block?
What price was he asking?
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 06-16-2013, 09:20 PM   #3
bigtruckboi2000
Re: 454block
Not sure how bad it's scored but will ask. I would like to use it as a mild bb in the 65 later on. And he was only asking for $300 for it.
Old 06-16-2013, 11:28 PM   #4
luvbowties
luvbowties's Avatar
Question Re: 454block
You'll have to buy cam and lifters; buy and install cam bearings; buy crank kit, includes matching rod and main bearings; buy 8 new pistons, and have them fitted onto rods; pay for re-conditioning rods; buy and install/fit new set of rings; pay for boring; buy full set of quality gaskets--price may shock you; buy better valve seals; pay for heads-refreshing/valve job; buy an intake and carb; buy timing gears and chain; buy an oil pump and strainer; pay for assembling engine(either your labor or someone else's); fuel pump--may hafta use an electric(more costly than mechanical) if no provision(??) for mechanical one; harmonic balancer?; new freeze plugs; flex plate or flywheel; front pulleys, brackets, accessories; exhaust manifolds; PLUS $100-$250 misc. I prolly missed. Add cost of all this and see the total.
Do you want to have that much in a re-built 454? I'd compare it to a decent-mileage, salvage-yard 454 where I could see the wreck it came out of--NOT one that was hit in the front where it may have damaged crankshaft and/or block internals.
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 06-18-2013, 06:49 PM   #5
bigtruckboi2000
Re: 454block
HTH,
Sam
Damn, now that you put it like that I think I'll pass this time. I'm no gear head by any means and this would be a (really, really) long term build and a first. I think I'll just wait until I'm closer to retiring and won't have to worry about changing duty stations anymore.
Old 06-16-2013, 11:45 PM   #6
gofastnut
gofastnut's Avatar
Re: 454block
Sam brings up an interesting point using a running big block. I just kinda like to build my own though. I'm shooting for 500hp for less than $3k--I know, I know, but I'm gonna try.
$2000-$2500 for a mild Big Block (gotta capitalize both B's, it demands respect!) is do-able. You can look in the "Engine & drivetrain" and "Racing & hi performance" Sections for some good advice and some decent builds.
Jeff
C-10 Club
Old 06-17-2013, 12:20 AM   #7
luvbowties
luvbowties's Avatar
Smile Re: 454block
Interesting, Jeff. I've not checked in quite a while, but what would a running, complete BB from a salvage yard, with acceptable miles, cost nowadays?
I'm pretty much up to date on sbc--but we do not run into many BB swap requests OR BB repair requests. In the last BB dealings we had, I do recall it cost us quite some time AND dollars just to locate the front brackets and accessories to do the swap.
Sam
Old 06-17-2013, 08:21 PM   #8
gofastnut
gofastnut's Avatar
Re: 454block
Hey Sam, I dunno either! I've always done SBC too! I was thinking of going turbo to be different until someone gave me a torn down 454 with steel crank and "049" heads!
I've always, and I mean ALWAYS wanted a rat motor. I know that it will cost me some $$, but not a serious amount more. And, as the saying goes "Ya gotta pay to play".
I know if you call a truck dismantler around here, you can pick up a complete stock serpentine set up, complete for $300.
Bigtruck, I say do it! The only regret you might have is not being able to pass a gas station. And if for some reason you don't like it, you can always pull it, sell it, and get a SBC.
First thing I'd do with that block it have them check it and see what it's gonna take to get cyl #4 fixed.
Oh yeah, hit Craigslist, Ebay and racingjunk fairly often to pick up some decent to excellent deals.
Jeff
C-10 Club
