68 C 10
![]() Join Date: Aug 2010
Which rear end do I have
Took the axels out and drum brakes off to rebuild with disc brakes. Need to know if I have to older rear end or the newer one measures 57 inches from plate to plate.
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
![]() Join Date: Aug 2003
Re: Which rear end do I have
If 12 bolt its 70-72. 5 lug 71-72
Posted via Mobile Device |
68 C 10
It is a 12 bolt.
![]() Join Date: Jan 2011
Measure your axles from the mounting surface (where the back side of the wheel would make contact) to the end of the splines. The early ones are 30 1/2" Later ones were 31 5/16" (not all were 5 lug.. some 6 luggers with the longer axles)
Usually if you find the OEM 5 lug axles they will be for the later rear end. Most 5 lugs @ 30.5" are some sort of aftermarket in my experience Hope this helps.. Chad
Widened housing in 70 still 6 lug. 71/2 5 lug.
68 C 10
Thanks chad they are the 31 5/16 inch ones
If you're swapping out and the bolt that holds the pin breaks when you take it out.. I have the tool to fix it.
Let me know.. 85% of the time the bolt will break off down in the hole. Major PITA to fix if you don't have this tool.. you're welcome to borrow mine. Posted via Mobile Device
68 C 10
I got the bolt out okay but the pin broke just above the hole where the bolt goes in the pin. Where would be the best place to get a new pin.
Eww.. I don't know. Humm
Let me look around.. PM Randy and see if maybe he has one? Post a WTB on the parts board maybe? .. in the mean time I will see what I can come up with. What ratio is in it now? Posted via Mobile Device
68 C 10
Not sure what gears are in it didn't have my glasses on today couldn't read what was stamped on the main gear I guess the ratio will be stamped on there this is my first rear end rebuild so I'm learning as I go.
Thanks for the help Posted via Mobile Device
