Old 06-28-2003, 01:44 AM   #1
BUXMAN66
go bucks!
do i need shock relocator brackets?
doin' the 3/4 drop on the 68 1/2ton w/ coil springs.i have the drop shocks for the project,as well as the adj. track arm.question is at what point in "inches of drop" do you need to go to relocating the shock brackets in back?is this only in lowering 5" and more....(c-notching the frame type of applications)?
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 06-28-2003, 02:30 AM   #2
67_SS396
I dropped the rear of mine 3" and it required the relocators. I could have done it w/o, but the ride quality would have suffered.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 06-28-2003, 03:13 AM   #3
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
if i remember reading right the magic number is 4" so yeah i'd go for it. It wont hurt at all... in fact it'd improve ride.. because of the shock being more actively involved. good luck
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 06-28-2003, 05:57 AM   #4
7T1BURB
I used the ECE shock relocation kit with 4" dropped rear coils on the Burb and it rides great. I suspect any more than 4" would require C-Notch to maintain ride quality, but could be mistaken.
7T1BURB is offline   Reply With Quote
Old 06-28-2003, 11:37 AM   #5
Smitty
Smitty's Avatar
I did just a spindle drop in front on mine and a 4-5" shorter coil in the rear. I just flipped the lower mounts swapping sides and used a spacer plate between them and the arms. Still run stock shocks and don't notice any lose in handling. Its down there and hugs the road corners like it is stuck to the road.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 06-29-2003, 10:06 PM   #6
BUXMAN66
go bucks!
thanks for the responses,any of you did this w/o relocating the shock mounting brackets....and how bad did it actually affect the ride?
Old 06-29-2003, 10:15 PM   #7
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I don't have them..... I couldn't tell you how bad it is compared to with them..... my shocks and springs were shot all the way around before hand. It is i little too bouncy at times though I don't know if the relocators would help that any.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 07-02-2003, 10:28 PM   #8
Smitty
Smitty's Avatar
The rides alright. After all it's no Caddy. I enjoy driving the truck every day. So I have no complaints. Might have should have used regular shocks instead of heavy duty gas. I love my truck!
Smitty
'71 Short Fleetside
Spring Valley, Ca.
