Old 06-19-2013, 11:20 AM   #1
ls1c10
ls1c10's Avatar
Indigo or Electron Blue?????
I just sent my 1971 fleet side to the paint shop but im having a hard time in picking a color and if I should run a cowl or stock hood. does any one have any pics of their truck in those colors. thanks
ls1c10 is offline   Reply With Quote
Old 06-19-2013, 12:02 PM   #2
SeTx67
SeTx67's Avatar
Re: Indigo or Electron Blue?????
Here's a build thread for one that's electron blue
http://67-72chevytrucks.com/vboard/s...d.php?t=483093
Here's another with Nassau blue
http://67-72chevytrucks.com/vboard/s...d.php?t=361864
I think jetstream blue would be awesome
SeTx67 is offline   Reply With Quote
Old 06-19-2013, 01:38 PM   #3
TonyJohnson
TonyJohnson's Avatar
I had a z-28 drag car that I had painted Electron blue. Loved the color!
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 06-19-2013, 09:42 PM   #4
Jayschevy
My truck's color is Miami Blue. A Dupont Nason color. I like it.
Jayschevy is offline   Reply With Quote
Old 06-19-2013, 10:36 PM   #5
TonyJohnson
Here's a pic of my Z28. Sadly I sold it... D1sc blown dyno'd 630 at the wheels...
More pics here: http://www.coloradoz06.com/zpics_blue.htm
Tony Johnson
Old 06-20-2013, 01:29 AM   #6
68bowtie
68bowtie's Avatar
in my opinion whichever is darker and/or more brilliant.
i think the cowls look ok if you're going for a pro-street look, but otherwise stock looks better. let the stance and wheels/tires make your statement. just my .02...
Old 06-20-2013, 09:57 AM   #7
ls1c10
ls1c10's Avatar
thanks for all the input.
Old 06-21-2013, 11:14 AM   #8
brad_man_72
the boat guy
brad_man_72's Avatar
Stock hood!
Too much going on with a cowl hood.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 06-21-2013, 11:26 AM   #9
TonyJohnson
That firewall is sweet. I like the steel cowl hoods on these trucks, especially since you're going LS...
Tony Johnson
Old 06-21-2013, 11:40 AM   #10
ls1c10
ls1c10's Avatar
So I decided to go with the stock hood, it still allows me to run the intake setup that I plan to use. thanks
Old 06-21-2013, 12:35 PM   #11
SeTx67
SeTx67's Avatar
Nice setup. Any details on the engine?
Imperial blue metallic is a nice gm color also. It's pretty dark though
Old 06-21-2013, 01:13 PM   #12
ls1c10
ls1c10's Avatar
engine specs.
* 2002 LS1 from a Camaro
* ~80k original miles
* Stock short block (block, crank, rods, pistons, etc.) never taken apart
* Stock heads (were pulled off to change the lifters)
* New* OEM head bolts
* New* OEM head gaskets
* New* LS7 lifters
* New* LS2 timing set
* New* Texas Speed "Magic Stick 3" (aka MS3) cam: http://texas-speed.com/p-1152-texas-...-camshaft.aspx
* PRC .650 lift springs (from TSP)
* Hardened pushrods from TSP
* Made 410 RWHP through the stock 4L60E automatic in the Camaro
* Just got SVO 30# injectors
Old 06-21-2013, 01:29 PM   #13
SeTx67
SeTx67's Avatar
Nice. I want to do a ls swap but that will be a while. I'll be watching for your build thread
Old 06-21-2013, 07:07 PM   #14
Square_78
Square_78's Avatar
Stock hood and the lighter blue. Cowl hoods don't look good on these trucks. Only run one if you need to for motor clearance. I also agree that Miami blue is a nicer color. Closer to factory for that era.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 06-25-2013, 12:11 AM   #15
ls1c10
ls1c10's Avatar
well I have changed my mind again. I went to a buddies shop and saw a dark gray color that they were using to paint the inside of a ford f100 cab. Its a 2013 vw gti carbon steal
so I got a sample and painted a spare fender. I used a spray can, so it will be better when it gets done at the shop. Il be using boss 338 wheels on the truck.
