GM ONLY BABY!!!
A/C wiring questions??
Is the Anti dieseling relay required for the a/c to work properly in my 72 GMC truck with a 6.0 ls in it?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
Re: A/C wiring questions??
At worst....You may need to jump the relay harness, Ive ran across these relays in '71 & '72 Chevelles, The C/K wiring may be different??
I think those anti-diesel capacitor relays are getting hard to find ![]() |
You won't need it.. all you need is the wire from the switch mounted on the diverter box to the compressor, or your pressure switches depending on what type of system you're running.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
GM ONLY BABY!!!
Ok. thanks for the help. Going to buy the Dirty Dingo bracket tomorrow. I am going to try to make the system work with the Sanden compressor, POA update valve, R134 dryer, and condensor, with the original accumulator.
You mean evaporator, right? If you're using the old POA system you won't have an accumulator.
I have a question about the anti-dieseling relay. My blower motor quit work when my relay quit working.I pulled the relay out and there is something rattling around in there so I am pretty sure it is bad. Can I bypass this relay somehow? Any help would be greatly appreciated.
![]() Join Date: Sep 2005
get a new relay?
They are hard to find. I bought a NOS of ebay and it doesn't work.
GM ONLY BABY!!!
I think LMC truck sells them.
I bought one at oreillys.
