newbie to forum. heres my ride
here is my 1966, i have had it for 15 yrs and am finally gonna get to start on it. i will have some questions later.
Posted via Mobile Device |
![]() Join Date: Mar 2005
Re: newbie to forum. heres my ride
Welcome to the site!
It looks like you've got a really solid truck. What are your plans?
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
Looks good!
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
Welcome, Cool truck, post some more pictures when you get it rolling.
![]() ![]() ![]() Nice ride! 15 years ? And it looks like that? WOW! I could have never taken that kind of suspense...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
yeah the suspense has been very hard to take...i kept it in a barn till now. bought 15 yrs ago with big plans then life happened
![]() ![]() Posted via Mobile Device |
![]() Join Date: Aug 2004
71/72 C10 if you can find one, those have coils and are 12 bolt 5 lugs. Otherwise, just swap out your axles to 5 lug and rebuild your diff to a more friendly ratio
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Senior Enthusiast
Excellent! Welcome to the forum. Looking forward to the progress.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
thanks on info of 71/72 rearend. being that early of 70s did any of those have the 308 or 273 gears, that is what ratio i was thinking if i keep the th350. or will i need to find one in the 80s?
![]() Join Date: Mar 2012
Welcome , good looking truck, I have a 72 v8 /automatic parts truck and it has 308 rear gear so to answer your question I would say yes
does a 72 also have disc brakes in front so i could swap frontend aswell while i was at it?
![]() Join Date: Aug 2012
Welcome to the forum !!!
71 was the first year for the 5 lug disc brakes and are basically the same all the way to the mid 80's. In 81 there was also a *light duty* rotor introduced which was 1" think were the 71-80 was a 1.25" thick rotor. They are now usually called the LD (light duty 1") rotor and the HD (1.25" heavy duty) rotor. You can run a newer spindle (either stock or aftermarket dropped spindle) on your older truck with a ball joint swap and/or a tie rod end swap, depending on the year of the spindle you choose. Here's some info on just that swap ... http://www.67-72chevytrucks.com/vboa...d.php?t=444823 |
thank you i will ck out that link. thanks to everyone for replying. everyones rides look grwat hopefully before december mine will be as they say "running with the bulls".
Welcome and great looking truck
#15 |
Slick looking truck bro, I'm starting my first truck and hope it looks this good by the time I'm done.
#16 |
hopefully this will just be the start for this old girl...
#17 |
60-66 Nut
![]() That's a good looking truck. Did you do the body and paint yourself, or did you have it done? There are links to many threads that will answer your questions, located in the 60-'66 FAQ index, found at the top of the page.
#18 |
Sharp looking truck.
I'll keep on watching. Welcome to the forum. |
#19 |
i bought the truck just as it is 15yrs ago and have not done a singal thing to it. 15yrs ago i bought it 75 miles from where i live and drove it about a quarter of the way home and it quit running, had to haul it rest of way home. come to find out the gas had been in it so long it had geled and gummed everything up. hasnt hit a lick since but all that is about to change
i have been trying to figure out what gears are in rear end.. i jacked it up and have both wheels in air...grabed one and turned it and the oppisite side turned the other way so i marked tire and then counted how many revolutions on driveshaft to turn wheel over one time which came out to be 3.75 so i figure they where 3.73's. but then igrabed wheel once again and truned it and that time the other wheel did not even turn....so not sure if what i did will work to tell me what i got? any advice from anyone would be great. Posted via Mobile Device |
#20 |
not sure if i should keep rearend i got and change from th350 to a 700r4. but i really want to change over to 5 lug so been thinking of trying to find donor truck cheap and just swap rearend and frontend out and use mastercylinder and column from donor...or just swap reared keep th350 and buy a conversion kit for front, but if i go that route then im stuck trying to piece power steering together...so many diff routes any advice from someone who has already done it....help
#21 |
I don't know if I could have not fooled with it in 15 years, you got more patience than I, of course having said that, I'm on my 13 year.
http://s1299.photobucket.com/user/jb...23904108567829 |
#22 |
Keep looking and reading on this forum and you will find any info you need, or post your questions. Captainfab is a guy to stay in touch with he has good fair priced products that will help you out and lots of knowledge available from everyone here. If your front suspension and steering is good you can just change the spindles and buy a set of rotors and calipers. There are some direct fit spindles out there, stock or dropped. 700r is not a bad way to go but you will get into drive shaft modification too. Good luck!
#23 |
thanks for all the good feedback on my old "beater" truck
#24 |
has anyone out there used the 21 gal gad tank offered from lmc to move their tank to behide rear axle? i am thinking bout doing this and just wondered if anyone already had and if they had any pics
