06-23-2013, 11:19 AM | #2 |
Re: at salvage now, are these rare or even from this area
Nope, just a cheap set of aftermarket gauges that someone hacked up a good dash to install. I know that's harsh, but sure hate seeing this.
06-23-2013, 11:43 AM | #3 |
Senior Enthusiast
The Stewart Warner gauges were quality built and popular when new, but are also rather common and readily available. The Sunpro gauge wasn't worth much when it was new. I agree with Tincan, it's a shame to see the modifications. Thanks for asking though, you never know, the next item you find might be the Holy Grail!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
06-23-2013, 11:54 AM | #4 |
Yep thanks guys
Williamsboy |
06-23-2013, 01:07 PM | #6 |
Or is this better of this inline 6? I have the Gilmer drive pulleysand I no I just need the v belt pully for mine. But will this mount on a 327
http:// Posted via Mobile Device
Williamsboy |
06-23-2013, 10:32 PM | #7 |
the 6 cyl power steering setup is gold ,I would snag it for sure , the V8 stuff looks like it may be for AC but I am not sure .... a keeper also in my book.. Even though I do prfer the late model serp. belt ....
06-23-2013, 11:20 PM | #8 |
the v8 stuff is not original 283, or 327, I don't think.....large harmonic balancer, long water pump, later PS pump (no nut holding the pulley) and those exhaust manifolds are later. No oil filler tube on the intake, and extra vacuum or PVC hoses, etc. That looks like a 350 to me. The stuff probably could all work on most any v8, but not for an original setup. The original PS brackets for our trucks don't look like that, but that may be for an A/C setup in later years? I don't think older 327 heads would have the mounting holes for those brackets.
06-23-2013, 11:23 PM | #9 |
I like the thrift air knob....picture #1
06-23-2013, 11:32 PM | #10 |
60-66 Nut
I agree with awbrown on the 6cyl PS pump. I would get that including the pulleys and idler and alternator bracket. Those are getting harder to find.
Regarding the small block PS. That pump and brackets will only work if you have a small block with a long water pump and heads with the accessory holes. You could use the pump itself, but not the brackets.
