Old 06-23-2013, 08:11 PM   #1
SethGR
SethGR's Avatar
14 Bolt 8 lug swap into 82 C10
I've found a 14 bolt rear axle, and all the front 8 lug running gear but haven't purchased it yet because I'm not to sure on what I need to check on the new axle to make sure that it'll be as easy of a swap as possible, will the springs line up or do I need to move the perches? do the shocks line up or again do i need to move them, the guy that im getting the axle from did the reverse on his truck and said he had to move the perches on his axle out 2in, but he had a 2+2 long bed 79 model, I've read that there are 3 different widths but the perches are all the same spacing on each of the axles. Can someone tell me what the differences between my 10 bolt and a 14 bolt are as far as spacing of perches and shock mounts, the only reason I'm doing the swap is because I want to have an rcsb c10 with 8 bolt and eventually a daully setup with fenders and all, and I searched a swap but none of the ones I saw were on a 2wd, which apparently affects the width, the guy that has the axle says the one he has didnt stick out any further than the 10 bolt he put in
SethGR is offline   Reply With Quote
Old 06-23-2013, 08:14 PM   #2
moregrip
moregrip's Avatar
Re: 14 Bolt 8 lug swap into 82 C10
http://www.pirate4x4.com/tech/billav...ble/index.html
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 06-23-2013, 08:24 PM   #3
SethGR
SethGR's Avatar
thats some good info but i need to know spring perch widths more than anything else, i may have missed that info in the article, im not afraid to cut and weld anything but im just trying to figure out if this is going to be a huge job or a quick swap.
and if i missed it please point it out
Old 06-23-2013, 10:19 PM   #4
moregrip
moregrip's Avatar
when my half ton gets here I'll measure them for you but I imagine the right answer will come sooner.
Old 06-23-2013, 11:16 PM   #5
MalibuSSwagon
Sounds like his truck is possibly a 1 ton. 1 tons have different width spring perches than the 3/4 ton and 1/2 ton. You can directly swap axles between 3/4ton and 1/2 ton trucks, springs perches line up the same.
MalibuSSwagon is offline   Reply With Quote
Old 06-23-2013, 11:19 PM   #6
mud.man.rj
mud.man.rj's Avatar
Yep, Malibu is right about that. 1 ton is different.
mud.man.rj is offline   Reply With Quote
Old 06-23-2013, 11:43 PM   #7
SethGR
SethGR's Avatar
SWEET! his truck was a dually with a flat bed, and he had to move the perches on the 10 bolt, maybe just maybe this other axle will line up because its a single wheel, might mean its a 3/4 and not a 1 ton.
Old 06-24-2013, 12:16 AM   #8
Liddy71
Liddy71's Avatar
I have a 86 c20 had the 14bolt I change to five lug had to change the perches and my shocks mounted inside on the 3/4 had to take the 5 lug shock hangers and move them to the inside where the 3/4 was .
Liddy71 is offline   Reply With Quote
Old 06-24-2013, 12:22 AM   #9
Liddy71
Liddy71's Avatar
I cant remember but when i did mine the 1/2 perches was 1 1/2 to 2" wide per side than the 3/4 I also have seen pics that some shocks on the 3/4 mount on the outside but is a 86 c20 crew cab
Old 06-24-2013, 12:23 AM   #10
Liddy71
Liddy71's Avatar
I cant remember but when i did mine the 1/2 perches was 1 1/2 to 2" wide per side than the 3/4 I also have seen pics that some shocks on the 3/4 mount on the outside but is a 86 c20 crew cab single wheel
Old 06-24-2013, 01:17 AM   #11
SethGR
SethGR's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1273762091
can some one tell me whose truck is this?
