Old 06-26-2013, 12:46 PM   #1
creed1969
Custom 3spd Shifter bushings
Hey guys,
I think I've made an improvement to the 3 on the tree shifter in my chevy... I searched for replacement bushings, and yes I do realize there are a few places you can get them, but I decided to step things up a notch.
I took measurements for top and bottom bushings, and did up drawings for them. Sent the drawings to a buddy who works at a metal fab shop, and they turned them on the lathe for me out of SAE 660 bronze. Here's the finished product!
And with the two parts assembled:
Got them home and installed them...they fit great! I sized them for an RC5 medium running fit, and it seems to have done the trick. The truck shifts with way more precision now.
So for anyone that keeps the 3ott shifter....and I know there's a few of us...here's an option to consider when your bushings wear out. Has anyone else fabbed bushings for these?
Matt. 16:26
'08 Sierra Reg Cab, shortbox - daily driver
'69 C10 LWB, 250, 3OTT - summer driver
'98 STi Type-R (JDM) <SOLD>
'97 WRX STi (JDM) <SOLD>
creed1969 is offline   Reply With Quote
Old 06-26-2013, 12:58 PM   #2
59bones
59bones's Avatar
Re: Custom 3spd Shifter bushings
Nice job and I bet it works way better than before.
I'll take a set if you plan on fabbing some more!
59bones is offline   Reply With Quote
Old 06-26-2013, 01:59 PM   #3
GRX
GRX's Avatar
Looks good! Bet they work great. Not for these trucks, but I have fabricated similar brass bushings on the lathe for the clutch and shift linkage in my '69 GTO.
Even in perfect working order I find column shifters to be cumbersome - lots of weight to move around. The three on the tree in my C-10 got yanked in favor of the Hurst floor conversion kit. Best thing I ever did to the truck.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 06-26-2013, 03:16 PM   #4
creed1969
Thanks guys, yes I would never argue that there is any advantage at all to shifting on the column...but there are three reasons I'm keeping it for now:
1. The far-away look in an uncle's or grandparent's eye as it brings back memories
2. The amazed/puzzled look on someone's face that has never seen it before
3. The great nostalgic feeling as I swing thru the gears.
Plus I've just got the I6 250 in front of it...so the only thing quicker shifts would do for me is shave a few seconds off my 30 sec 1/4 mile...
Matt. 16:26
Old 06-26-2013, 03:27 PM   #5
GRX
GRX's Avatar
All valid reasons. No arguing the nostalgia factor! Over the decades I have owned a few cars & trucks with column shift - both GM and Ford. As you can see from my sig, my C-10 is a 250 as well. To me it just got old shifting in heavy traffic. Much less elbow & shoulder grease required when the shift knob is at the seat next to you. So once the time came to rebuild the linkage I did the swap.
Think I'll pull the column shift rods off the wall again just for fun.
Old 06-26-2013, 04:02 PM   #6
88Ironduke
Great product. If you decide to mill out another set let us know!
88Ironduke
88Ironduke is offline   Reply With Quote
Old 06-26-2013, 04:43 PM   #7
cericd
cericd's Avatar
88Ironduke
Agreed.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 06-26-2013, 05:36 PM   #8
Kidd-7
Kidd-7's Avatar
88Ironduke
Awesome, I want some too...
71 C-10 - 307 - 3 on tree
01 Ford Explorer 5.0 v8
96 Mercury Cougar v8
79 Trans Am 403 Olds
Kidd-7 is offline   Reply With Quote
Old 06-26-2013, 05:53 PM   #9
54blackhornet
54blackhornet's Avatar
I would like a set also !
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 06-27-2013, 12:25 PM   #10
creed1969
Wow maybe I should do up some more hey? sounds like there would be some demand. Unfortunately the bronze stock is pretty pricey. Just the material alone cost around $50, (1" round bar) and I was fortunate to get the machining for free.
Its these sorts of little custom upgrades that makes building these trucks so much fun
Matt. 16:26
Old 06-28-2013, 04:02 PM   #11
GRX
GRX's Avatar
Yeah, that sounds kind of spendy for 660 bronze. $50 for the whole bar or just what was used for the bushings?
Pricing:
http://www.onlinemetals.com/merchant...=761&top_cat=0
Old 06-28-2013, 04:24 PM   #12
68gmsee
Active Member
68gmsee's Avatar
Or,,, at least post the measurements you have for us brother truckers.
Those look great on the truck. I made my own out of metal tubing and rubber hose many years ago. So far they've held up and work good but they're nothing to look at.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 06-28-2013, 04:35 PM   #13
Sixteen Tons
Sixteen Tons's Avatar
I was recently doing some adjustment on my 3OTT, (250 I6 as well) and though it really helped with shifting, I did notice how sloppy of a fit it was under the cab. I put together some miscellaneous things from the bench top to see if it would work (sorta), but I would definitely be interested in a set of properly fabricated ones. If you make 'em, we'll take 'em......
Sixteen Tons is offline   Reply With Quote
Old 06-28-2013, 10:10 PM   #14
Russ.W.
Russ.W.'s Avatar
Nice work!
Was thinking the same thing. Rather than the hassle/expense of getting them made for everyone, maybe be generous and share the measurements & drawings?
Old 06-28-2013, 04:46 PM   #15
DjS71
If nothing else, post the measurements. That looks fantastic, all of us boys with the ol' sloppy 3OTT are jealous.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 06-28-2013, 11:15 PM   #16
oklalawnboy
oklalawnboy's Avatar
How much do you think they would cost if you added your labor? I would be interested in having a set too.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 06-29-2013, 01:04 PM   #17
Kidd-7
Kidd-7's Avatar
I also notice that one of those bolts is nice and new looking, did you just clean it up and paint it or is that a new bolt? If new, where did you find it at? Thanks.
Old 09-07-2013, 12:28 PM   #18
data89
Thumbs down Re: Custom 3spd Shifter bushings
Where can you purchase these?
data89 is offline   Reply With Quote
Old 10-06-2013, 02:22 PM   #19
TheOcho
TheOcho's Avatar
I redesigned the shift bushings on my 78. These are the prototypes I made from mild 1018 steel. They are adjustable for wear. These two are currently installed on my truck and they work great. I'm currently working on a set made of 4140 chromoly (pre-hard) for greater wear resistance. The 78 doesn't use metal bushings on the column end, only at the transmission, hence the reason why there are only two.
The pic isn't that good, but it's all I have.
TheOcho is offline   Reply With Quote
Old 10-06-2013, 02:24 PM   #20
TheOcho
TheOcho's Avatar
Here's a pic, comparing the factory bushing to my bushings.
Old 10-08-2013, 10:29 AM   #21
kray59
kray59's Avatar
Cool Re: Custom 3spd Shifter bushings
I would be interested in a set also . thanks , kenny .
This is MY rifle.There are many others like it but this one is MINE.
Beware the man who only owns 1 rifle , he probably knows how to use it.
kray59 is offline   Reply With Quote
Old 10-08-2013, 11:14 AM   #22
creed1969
Wow I'm astounded at your guys feedback on these! Thanks for the interest! I don't intend to do another batch of these, but here are the drawings I provided to my machinist...provided for "reference" only.
I hope these work for you guys, at least they save you the time of making your own drawings.
Cheers, Colin
Matt. 16:26
Old 10-08-2013, 12:25 PM   #23
Keith Seymore
Keith Seymore's Avatar
Cheers, Colin
Hey - I noticed there are no signatures in the "checked" and "approved" boxes.
We can't archive those until they are completely signed off...
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-08-2013, 12:33 PM   #24
creed1969
Haha, relax. As the originator I am taking the liberty of skipping all checks and approvals lol. In this case the bold red FOR INFORMATION stamp covers a multitude of sins.
Matt. 16:26
