06-28-2013, 01:51 PM | #1 |
Driveshaft shortening
I'm doing TH 350 to 700r4 swap on my 1972 C 10. Can someone tell me how much the driveshaft has to be shortened or if there is a stock replacement? Thanks
06-28-2013, 02:23 PM | #2 |
Re: Driveshaft shortening
1 piece or 2 piece shaft?
'67 C20 LBW |
06-29-2013, 09:16 AM | #3 |
06-28-2013, 02:29 PM | #4 |
the boat guy
Measure your truck!
There's so many different ways to put an engine in these trucks that its mind bending. 6cyl mounts, v8 mounts, big block mounts, swap pass to drivers side mounts and a couple of different places on the frame to bolt them in. Take your old shaft to a driveline shop (both pieces if its a 2 piece driveshaft) with a tailshaft to center of rear joint measurement (tailshaft to center of carrier bearing for 2 piece) have them shorten and ballance your shaft. Its pretty cheap and you will have a shaft that you can actually use when you are done. If your old shaft was the correct length to start out with and you don't move anything else around it should need to be 2.5" shorter I believe. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
06-28-2013, 03:45 PM | #5 |
to have the driveshaft done once and only pay for that service once it wood make sence to measure it yourself a few times so it is dunn right
06-28-2013, 03:50 PM | #6 |
Junior Member
I would suggest taking the truck with you so there is no margin for error.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
06-28-2013, 04:12 PM | #7 | ||
"I ain't nobody, dork."
I was looking for the Crisco!
Gary
06-28-2013, 06:20 PM | #8 |
a 700r4 is 3 1/8 inch longer than a short turbo 350
turbo 350s were made in 3 differing lengths |
06-28-2013, 10:50 PM | #9 |
I had mine cut at 2 1/2 inches but the only way to know for sure is to measure it yourself.
1970 GMC truck 1988 Harley 1200 Sportster |
06-29-2013, 07:50 AM | #10 |
A driveshaft from a 6 cylinder truck works with your motor in the forward location.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
