06-29-2013, 10:47 AM | #1 |
Need help replacing wheel bearings
I broke down today and decided to replace the old ball-bearings on my '52 half-ton with the roller-bearing conversions. I ran into a problem immediately and need your help. The inner race will not come off the spindle. I guess that is what it is called. It is the race that fits over the spindle and rests against the brake backplate. Should it just slide off? I have tried tapping a chisel between it and the backplate...nothing. I have tried grabbing it with pliers and twisting...nothing.
I have it sitting right now with penetrating oil soaking into it. I supposed I could apply heat, but with that brake cylinder sitting right above it I'm not sure I want to do that unless it is a last resort. Please help. daveboy |
06-29-2013, 11:02 AM | #2 |
Re: Need help replacing wheel bearings
I've fought that fight a time or two. You are doing exactly what I would do but you may have to heat the race to get it off. I don't think there is much worry about the wheel cylinder as you can get the race hot enough to expand it a bit pretty quick. just concentrate the heat from the torch on the race.
06-29-2013, 02:05 PM | #3 |
If you have a Dremmel tool, you might try cutting the race with a small cut off wheel. I had to do that once only because I didn't have a torch.
Posted via Mobile Device |
06-29-2013, 05:03 PM | #4 |
i'd try heat first, even a propane torch might do it, a little heat does amazing things to tight races
if that fails use a grinder with a cut off wheel, cut diagonally across the race and split the race with a chisel you might damage the spindle a little, no worries, polish the surface with some emery cloth and slide the new race on
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
06-29-2013, 06:39 PM | #5 |
Well, I tried the heat from a propane torch and that did the trick...but just barely! I got it wedged out just enough so I could get the claw of a 4' crowbar in behind it. I kept prying on that while my son kept the torch on the race. I didn't think that sucker would ever come off, but I finally got it. I got the one hub all done today. Will start the other one in the morning and I hope it is a little easier.
Thanks for the help. daveboy |
