06-29-2013, 04:26 PM | #1 |
New wheels and tires
I finally broke down and ordered my wheels and tires. I went with the Cragar Classic 69 series wheels 15x8 square set up. For tires I ordered Cooper Cobra GT 245/60 front and 255/60 rear. Also added the 3" port-o-walls.
The spider caps that Cragar sells for the wheels are only available in 5 lug. Since I am still 6 lug I went with the Gorilla Bullet centers with matching bullet lugs. |
06-29-2013, 04:29 PM | #2 |
Re: New wheels and tires
06-29-2013, 11:03 PM | #3 |
Cant wait to see umonthe truck... Curious how the port-a-walls holdup.... Heard good and bad about them.
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
06-30-2013, 01:41 AM | #4 |
Love the wide whites. Get them on the truck and upload pics, maybe even one with a pin up girl would be nice
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
06-30-2013, 11:56 PM | #5 |
07-01-2013, 12:04 AM | #6 |
Can't wait to see how it looks lowered.
~ Dave '68 C10 Stepside: 350/700R4 |
07-01-2013, 03:35 PM | #7 |
07-01-2013, 06:06 PM | #8 |
Subscribed. Lets see that drop.
07-01-2013, 10:22 PM | #9 |
Springs and blocks came today. Already have the shocks. Just waiting on the control arms.......
07-01-2013, 10:48 PM | #10 |
what is a porta wall?
07-02-2013, 07:24 AM | #11 |
Watch out for your cornhole !
It's a fake whitewall. You put them on your black wall tires when you're mounting them to get the whitewall look.
They have been around for 50 years or more. Cheap way of making any tire into a wide white. They do have their downsides too though. Posted via Mobile Device |
07-02-2013, 12:13 PM | #12 | |
07-03-2013, 01:10 AM | #13 | |
Ooooh, learn something new everyday |
07-02-2013, 12:16 PM | #14 |
Where did you get the porta walls and bullet caps?
07-02-2013, 11:41 PM | #15 |
Port-o-walls from Lucas Tire
http://www.ebay.com/itm/15-x3-Portaw...item338345eff4 Summit Racing for the bullets. They have two different center bore sizes. Mine are the 4.25 http://www.summitracing.com/parts/gor-hc216bt |
07-03-2013, 11:18 AM | #16 |
Looks sick!!! The drop is gonna set it off!
Posted via Mobile Device Posted via Mobile Device
07-03-2013, 07:02 PM | #17 |
Nice.... I like it!
07-03-2013, 10:29 PM | #18 |
I think I am gonna go that route with my steelies.
07-03-2013, 10:56 PM | #19 |
optomistic ah-so
The most common complaint about Porta-walls is how they yellow and crack over time. You're very likely to change your wheels and tires before it happens. Some patina admirers might even appreciate seeing aged Porta-walls instead of white ones.
If you want to stretch out their life though, DON'T use silicone protectant (most tire shine, dashboard products). You need to kill the effects of UV. Try a real wax, again not silicone, but the polymers are OK while earlier formulas let them "breathe" better. You may prefer neutral shoe polish, or even painting over it with a craft store semi-gloss clear coating for preserving artwork.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
07-04-2013, 03:02 PM | #20 |
07-04-2013, 03:08 PM | #21 |
PROJECT 7DEUCE
Truck looks good with the white walls and black smoothies.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-04-2013, 03:10 PM | #22 |
Check that you have both front springs clocked properly. The end of the bottom loop should set into the control arm in the little groove made for it.
Also make sure your upper ends of both coils are seated in the upper mounts. Both springs should be located in the middle of the round cutout in the crossmember. Usually a pry bar or even driving it a bit for a few blocks will seat them. You'll hear a pop noise and feel it settle into place. Posted via Mobile Device |
07-04-2013, 03:13 PM | #23 | |
07-06-2013, 06:39 AM | #24 |
laying low
Nice improvement with the drop. A little fine tuning and it'll be set.
07-06-2013, 03:02 PM | #25 |
Very nice. Great look
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
