hood hinge hell, help!
I am having a heck of a time trying to get my hood aligned right. The truck was hit on the right hand side in the very front and had everything shifted to the left. Got everything straightened out pretty good but my hinges were bent, so i got 4 pairs from special-k to find a good set. Took the springs off all to find the ones with the least amount of play and mounted themand the hood. Now iam having issues with the back of the hood not going down all the way and to the same spot. I have to go to each side at the rear and push down? Is this miss alignment on my part or worn hinges? My oe ones did not do this but I had taken the springs of them and they have the exact same play, movement as 2 sets that I got from special-k? At a loss here and need some help.
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
The Older Generation
Re: hood hinge hell, help!
To get the back down open the hood, loosen the three bolts that attach the hinge to fender (both sides). Now push the hood up till the hinges stop moving, then push it open a bit more to pre-load the hinges, then tighten hinges. You will need two people to do this. Now SLOWLY lower the hood and watch to make sure that it doesn't hit on either side or the rear. It may take a few tries to get it to sit just right height wise. You may need to adjust the hood front to rear to allow for proper clearance with the cowl.
LockDoc
Eat, Sleep, Drive a Chevy
If your only problem is the back of the hood is too high I agree with LockDoc you need to lower the hinge in the rear, follow his instructions. I had to ream the hood hinge bolt holes a little on mine to get the hinge to go as low as I wanted.
I would only ad that if you were hit in the front and the impact was straight back toward the cab nevermind but if the impact was from the right side towards the left or vice-versa the core support could have shifted over and cause the hood not to align along each side. good luck
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
Thanks guys, will try the preload procedure. The will go low enough in the rear it is after it is opened it will not seat back down all the way.
I have shifted the core side to side to get a happy medium and good lines. Trouble is only with the rear of the hood, hopefully till i try your suggestions. Thanks and will report back with how i make out today.
It will work if the small sloppy link rivets are not too worn out. GMC Paul mentioned before of someone who can rework them. Might be worth while to start just having a spare set rebuilt if you have too much trouble with them rather than investing in replacemnts.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
if the rivits are loose i've bought some time with them by pressing them in a shop press. of course it takes some setup time so you only squish the rivit an not anything else(i've only done this on camaro hinges but they'er all basicly the same an it worked great).if its only the rear of the hood locdoc has your cure.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Yes the rear only, was able to get it really close, i had never preloaded the springs after taking them off. Still have some left to right adjustments to make but i think in the park now. I might get them rebuilt once i tear apart for paint.
