Best way to replace a front spring hanger bracket?
My drivers front spring hanger bracket on a 1972 chev 1/2 ton 4 x 4 looks like it has been worked on with a grinder and welder. The spring bracket where the eye bolt of the spring goes thru is no longer at a right angle to the frame. This is twisting or putting pressure on the leaf springs sideways.
In trying to replace a hacked spring bracket can bolts be used in place of rivets? What other procedures are necessary to secure the bracket to the frame? Br. |
Re: Best way to replace a front spring hanger bracket?
If you use grade 8 nuts and bolts you'll be fine.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Thanks, spring is loading and unloading the shackles with the eyelet on a twist going thru gutters, no problems on a smooth road. Br.
