![]() Join Date: Feb 2013
problem after ece 4.5/6 drop
hi
dolly gt his drop 4,5 in the frnt with drop spindels all from the kit from ece and 6 in the rear. my problem know is that my wheels won t fit know they touch the lower arm and the spindle where the steering rod is fixed. i don t know the size of the wheel but i think these are 15x10 with 4 and a bit backspace there are 275 60 tyres on it. the backspace is sure 4 and a bit i measured 10,5cm. which rallys could i buy wh fit? classicindustries has them in 15x8 with 4 backspace would that fit? i will run with 245 60 or 255 60 tyres... maybe there is someone who has thies drop with these rally wheals... thanks a lot
Loving my Dolly ![]() Greetings from Germany Andy |
Re: problem after ece 4.5/6 drop
i have 15x8 with 4" BS and 255/60/15s on the front and have no issues.
68' c10 stepper 5.3/4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
That backspace on a 10" wide wheel definitely wont work. Stock rallys in an 8" flavor certainly will though.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
if a 10" wide rim with a 4 backspace hits spindle and control arm // an 8" wide rim with a 4backspace will hit the exact same places
That is a really wide front wheel.
Do you have any before/after pictures of the drop? I know this doesn't help out at all, lol.
You remember when drinking too many beers was a bad idea? Me neither. |
Thats what i think too need less backspace... does this exists?
Rally wheels with lessvthan 4 bacj space? I will post pics when i am at home again maybe tomorrow... greets Posted via Mobile Device
Here is an after pic
![]() Sorry for the long waiting... i d had alot of other stuff to do and my dolly is parked in the garage since the drop;( I don t know which rallyes i should order withe the drop... Does anyone has a shop where 8 could buy some? I found a set on classic industries but to send them back from germany if they wont fit is expensive and take weeks... What do you think?
#8 | |
laying low
![]() Join Date: Mar 2001
![]() Join Date: Sep 2012
I don't think you have 10" rallys those look like 8" rallys or could be 7's.I would make sure before you end up ordering the same wheel.Good luck great looking truck
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
Check out this thread to understand the BS on various rally wheels. With the drop you have 4" BS is the max you can go.
http://67-72chevytrucks.com/vboard/s...d.php?t=462895
1970 C10 Short Stepper with 71/72 front clip. |
Moderator
![]() Join Date: May 2007
You don't need new wheels. Just trim your lower control arms as outlined in post six by lowlife99: http://67-72chevytrucks.com/vboard/s...d.php?t=416186
Nice truck...looks like my twin! I have a 5" drop up front and run 15 x 7 rallies with no issues after trimming the lower arms slightly.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
thx fr the replys i will measure it out and look t trim the lower arm...
the problem f the spacer is that in germany the must have some papers sheets where they are proven, i dont get them... so i trim and the guy who checks the car every 2 years will not see it ![]()
@leddzepp wich tyre size are you running?
