Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 07-02-2013, 09:05 PM   #1
l79m20
07 Cruise Control Problem
So my 07 wont allow the cruise to work. Ive checked all threads, read through the "easy fixes" , I have replaced the brake light switch and still no go. I have tried to trouble shoot it to the best of my ability, but I have not been able to make it work. According to everyone else with the problem, its as simple as the brake light switch. Anyone else have any other ideas? Thanks
l79m20 is offline   Reply With Quote
Old 07-08-2013, 09:14 PM   #2
l79m20
Re: 07 Cruise Control Problem
any ideas??? Still cant figure out the problem.....
Old 07-24-2013, 06:21 AM   #3
poncho_villa
poncho_villa's Avatar
Was it part number A/C Delco# D1586H, GM# 15861245. All you need is a 10mm wrench and a small screwdriver to pry the clip apart? Is that the part you replaced?
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 07-28-2013, 11:11 PM   #4
l79m20
Yep. That was it. Still wont work.
Old 08-11-2013, 11:06 PM   #5
l79m20
Still have not made any progress yet. I cant get this figured out.
Old 08-28-2013, 10:29 PM   #6
mcmlxix
Collector of Projects
mcmlxix's Avatar
I would be interested to know as well. Just bought a high mile 08 Sierra RCSB... the little light on the steering wheel comes on... no light on the dash to say its engaged....
Rich
1972 K5 Blazer CST Click HERE
Old 08-29-2013, 02:12 PM   #7
slug
slug's Avatar
check your brake fluid level. if the level is low, it will not allow the cruise control to engage.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 09-03-2013, 08:06 AM   #8
mcmlxix
mcmlxix's Avatar
Is there a specific fuse associated with the cruise control?
Rich
Old 09-03-2013, 01:27 PM   #9
l79m20
no fuse. I have a light for my abs on also. I have read that the speed sensors go out and that could be the problem as well. But they are expensive.....
Old 09-03-2013, 05:53 PM   #10
mcmlxix
mcmlxix's Avatar
If the speed sensor was not functioning, the transmission wouldn't be shifting correctly and the speedometer wouldn't be working...
Someone on another board asked if brake bulbs were swapped out recently? My turn signals flash at a fast/erratic rate and it looks like my right rear tail light had water in it (looks corroded)... I'm thinking it may be part of my issue...
Rich
Old 09-03-2013, 06:54 PM   #11
l79m20
Thats a good point. I will take a look at my bulbs tonight. I know the lense on my passenger side has a small crack and hole in it.
