07-03-2013, 07:54 PM | #1 |
well .... what do i do now, ready to give up
anyone else have this problem?
1986 LWB c10 w/327 & vortec heads |
07-03-2013, 08:00 PM | #2 |
Re: well .... what do i do now, ready to give up
Yup. Look on the bright side, yours looks pretty mild. When my windshield was pulled because it was leaking, you could paint stir stick through a couple of the holes at the edges.
Proud UA member since 2009 My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660 Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA |
07-03-2013, 08:02 PM | #3 |
hard to fix ? im pretty pissed off at the moment...
07-03-2013, 09:40 PM | #4 |
That's not too bad, I believe the two bigger holes on each side are factory drain holes. I had similar rust, just wire wheeled it, por15 and new window seal.
Posted via Mobile Device |
07-03-2013, 10:19 PM | #5 |
http://67-72chevytrucks.com/vboard/s...d.php?t=433819
Doesn't look too bad, totally fixable check out my rust repair thread. I'm from Ontario too I feel your pain when it comes to rust. Posted via Mobile Device |
07-03-2013, 10:19 PM | #6 |
Not too hard to fix. Weld in a patch panel if it's really far gone, or build it up with some metal epoxy and sand back to the original shape.
07-03-2013, 10:21 PM | #7 |
suck it up tough guy, that aint bad at all!the big holes are drain holes, wire wheel it weld up the pin holes paint it and be done with it!
"DON'T TOUCH THE TRIM!!"-Early Kyler |
07-03-2013, 10:43 PM | #8 |
use some Rust Bullet on there....put it back together no one will know....
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
07-03-2013, 11:06 PM | #9 |
Moderator
Man, don't freak! That's not bad. I guess if you don't have a welder or access to one it could be complicated...but every truck problem is an opportunity to buy tools, right?
A few small pieces of 18ga metal, cutting tools, shrinker/stretcher and welder and you'd be fixed up in an hour or two.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
07-03-2013, 11:22 PM | #10 |
haha yes sorry for over reacting guys ! just seems like everything that could go wrong with this thing HAS! the reason i took the windshield out in the first place was because the asshole that sandblasted my frame also blasted my glass ... also he decided to try to fix my floors and they look like he welded them in with a pineapple but ill try to get my hands on a welder tomorrow i guess ! wish me luck haha
07-03-2013, 11:56 PM | #11 |
That looks like an easy repair to me also.
My tip of the day: When welding sheet metal keep bead less than about 1/2" long and allow cooling to avoid major warpage. |
07-04-2013, 11:05 AM | #12 | |
If you weld a half inch long bead in sheetmetal that thin, you will warp it like crazy. Small tacks are all you can get by with and even then you have to move around to spread the heat.
Allow it to cool on it's own before continuing.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
07-04-2013, 12:28 PM | #13 |
I've welded less than about 1/2" long many times w/o warping.
I weld longer passes on flat sheet metal w/o warping. I agree that a small tack is less likely to warp and better advice if newbie decides to learn welding on critical part. I also agree about allowing each tack weld to cool down on small patches. I find tacking boring (but safe) and pushing the puddle kinda fun. I'd recommend newbie practice welding on scrap, then floor pan, then more critical areas. |
