Blazer Hardtop brackets
I desperately need the brackets that hold the blazer top to the windshield frame. I found a local guy with a double wall, still looking for a single wall. thanks
Scott
67 Impala SS Conv 66 Caprice 396 No more trucks.... someday though |
SKINNY TIRES RULE!
which brackets? The ones that have the sunvisors, the other two, all four?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
I didn't realize there were different types of these, whatever you have, I just need to keep the hardtop on.
Check out coloradok5. They may have something for you.
69 Chevy swb 72 blazer 4wd |
I have set of brackets from a 72 DOUBLE WALL TOP? Do you have a pic somewhere of what your looking for?
I have a few other blazer parts laying around also? |
I don't have any pics of these, can someone take a pic of theirs?
TrucknVA, I sent you a PM. Thanks, Scott
![]() Join Date: Dec 2000
Here is a pic of the brackets(need two) that go in the center. If you have sunvisor brackets, you've got the outer ones. In the sunvisor brackets there is a hole to put a bolt thru to screw into the top at the corners. If you don't hook up with some one else I've got what you need.
Thanks, Matthew
GOD is good...All the time! '71 swb custom10 barn find-68K original miles 72 K5 CST rust bucket, but runs and drives 84K miles |
Were the bolt pattens on windshield frame and top the same regardless of which brackets you have? I have a separate pattern on my windshield frame for the sunvisors like the pic shown, so are there two types of windshield frames and two types of bolt patterns for single and double wall tops? Was one pattern for the single wall and one for the double? Thanks for the clarrification guys, I thought I knew all about these trucks, fun learning again.
Scott
Scott-To the best of my knowledge both tops buckle down the same on the windshield frame, they only bolt different on the bedsides.
Matthew
