Re: 1959 spartan 80 frame swap
did you measure the width? if it will fit I think it would be a cool swap!
Disabled Vet, Desert Shield/Desert Storm Veteran "Proud to have served" 1965 C-10, 1965 C-60, 1966 C-10, 1975 C-20, 1986 M1009 Blazer, 1987 GMC 1/2 ton suburban, 1995 1500 Suburban 4x4, 2001 2500 Suburban 8.1L |
X2 for a cool swap, still have the old cab, and a frame that you could do serious work with
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD 73 k5 gm crate 350-265 / sm465 / np205 3.73 posi |
The 1959 spartan 80 the front track is 71.25 inch's
and a friend told me that the 1995 3500 HD is about 70.50 but I want to measure everything else to make sure that it will fit next week I will go measure it in the scrap yard |
Professional Crow Bar Tosser
I'll be following this thread. Definitely wanna see that swap. Sub'd!
Will My Beast "Big Nasty": '92 GMC Sierra K1500 Ext. Cab L31 Swap 4x4 Conversion: 2" Body Lift, 3" Skyjacker Suspension Lift, 9.5" 14-Bolt G80 Rear, 3:73 Gears, 350cid L31 Vortec 5700, 4L60-E Overdrive Automatic My Dad's Beast: CUSTOM '97 Chevrolet Silverado K3500 4-Door Mega Cab Project: 10.5" 14-Bolt G80 Rear, 4:10 Gears, 5.7L 350cid SBC Vortec, 4L80-E Overdrive Automatic "I'd rather PUSH my Chevy than DRIVE your Ford!" |
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
This will be an interesting and cool project.
Keep us up to date on your findings and post lots of pics!
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
i would just put a flatbed on it and rock it!
"DON'T TOUCH THE TRIM!!"-Early Kyler |
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Did this ever get off the ground...its an interesting idea
1963 Chevy C10 (under construction).....build thread 2009 Honda Shadow 2008 Mazda 5 2013 Ford Sedan Interceptor AWD 2017 Harbor Freight 4x8 trailer (great for hauling parts) 2017 Honda Rebel |
i just bought last week a 1999 3500 HD
so in couple week i will start the project |
Cool to finally see another Spartan around! I have a Spartan 100.
1955 GMC Hydramatic 1959 Chevy Spartan 100 1969 Chevy C/10 1969 Chevy C/30 Bruiser 1972 GMC (Wrecked) 1972 GMC pickup..old blue Restored Vent Windows https://67-72chevytrucks.com/vboard/...d.php?t=766598 1955 GMC hydramatic build http://67-72chevytrucks.com/vboard/s...d.php?t=429417 ![]() |
Didn't know there was a 100, thought c90 was the largest
#15 |
I had a 10400 series truck at one point. It was a 59. Factory 348 5 speed/ 2 speed.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
#16 |
#17 |
Any updates?
1986 K-10 ![]() |
#18 |
I'da done it the other way.............put the newer axles under the original Sparton .
What do you expect to use the truck for ? Canadian model numbers on GMCs are inverted compared with US models. I have a few Canadian GMC brochures.........and pictures . And then there was "Maple Leaf" ! |
#19 |
Here is mine. Its a 1958 60 Viking on a 1998 chevy 3500 chassis. Not an HD though. I could not find an HD that fit my pricerange and criteria.
Not hijacking, I will be doing a build thread here in a few weeks. Just posting a few pics for the reference. |
#20 |
Pretty sure that's the best looking bed I've seen. Nice truck!
#21 |
Nice truck warrior 9 and its look pretty low . is your cab close to your frame ?
#22 |
#23 |
looking good
#24 |
Looks nice!!!! One question. Could you move the engine crossmember up about 3 inches? Might move the engine just enough so you wouldn't have to cut the cab or valve covers.
#25 |
yes i can but if i keep the motor in the original motor location my corvette headers fit perfect , a long water pump fit perfect, and my drive shaft fit perfect , so it cheaper to modify the cowl dash a little .and use the part I have in stock . I will maybe pull the cab toward the rear just to clear the valve cover and check how the wheel look in the fender
for now its center ![]() Last edited by DG Racing; 02-23-2014 at 07:03 PM. |
