Old 07-09-2013, 11:35 PM   #1
Jaysonb
Jaysonb's Avatar
Trans leak question
I picked up a th350/203 to replace my junk trans. It looks like its leaking where the tc bolts to the trans, is this just a unbolt, clean up and rtv deal?
Jaysonb is offline   Reply With Quote
Old 07-10-2013, 08:53 PM   #2
raceman6135
Dino burner
raceman6135's Avatar
Re: Trans leak question
By "tc" do you mean "torque convertor?" If so, no, because the torque convertor does not bolt to the transmission: it simply slides over the transmission's input shaft into the pump. No fasteners of any sort are used.
At the front of the transmission, there are a number of places where it could be leaking:
- the torque convertor to front pump seal
- each bolt that holds the front pump to the transmission case has a small seal on it
- pump to case gasket
- o-ring seal between the pump halves that also seals to the case
- transmission fluid pan
raceman6135 is offline   Reply With Quote
Old 07-11-2013, 08:07 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I figured he meant transfer case.
Tx Firefighter is offline   Reply With Quote
Old 07-11-2013, 11:08 AM   #4
Jaysonb
Jaysonb's Avatar
It is leaking where the transfer case adapter bolts to the transfer case. Just wondering if I need to find a gasket, or if rtv will work here.
