Project Heaven in my 67!!!
Popping in the exhaust
So, Ive been dealing with this situation and wanted opinions before I go and dump money into the truck.
A little about the truck. It is an 87 TBI 350 with 700R4. I am getting a popping noise in the exhaust. I thought it was back firing through the exhaust. So I checked timing and gave it a complete tune-up (plugs, wires, cap, rotor, PCV). Checked timing again. All checked good. Purrs like a kitten minus the popping in the exhaust. My father and I think that it is a baffle in the muffler come loose and slapping the inside of the muffler. But, I am not convinced. I need to replace the exhaust anyways and have a set of 40 series flows for it. But, before I spend the money to do that, is there a way to check to make sure it isnt a backfire? Suspect maybe a burnt valve or some carbon caked up somewhere allowing fuel into the exhaust. |
Re: Popping in the exhaust
could be lean
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
Mine does it also. Have new exhaust from engine back. Ive changed cap, rotor, plugs and wires. I checked the vacuum and its good but erratic at times. I have some play in my distributor so I am changing that next. that coulb be your prob.
This is on deceleration right?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
take a look at the catalytic converter. they are notorious for falling apart and blocking airflow. they can rattle n grumble n block airflow thru the exhaust.
Mine is at idle. No cats on my ride. Its just a slight popping while at idle. Like a small miss. Im restoring her so when I pull the cab off I will change the distributor. That could be it.
need to do a leak down test. could be bad exhaust valve or exhaust valve seat. the pop is probably from explosion in cylinder with exhaust valve not closed all the way or "sealed". could also be carbon build up on piston...I would do compression and leak down test and go from there, cover the basics first.
79' GMC stepside...the money pit! ![]() 355 aluminum partoit heads 2.02,lunati 268 flat tappet,comp roller rockers 1.6,hi-tech torque link intake(Jim McFarland),electric water pump,650 holley double pumper,msd 6al,msd street fire dizzy,doug's long tube headers(ceramic),3" exhaust(flowmaster 40) |
![]() Join Date: Mar 2013
I agree with Lunchbox. I went through the same thing before....bad exhaust valve sealing. If you recently changed the plugs i'd pull them and look for one that looks different from the rest. If there is one that doesn't look like the others do a compression/leak down to verify poor sealing.
Posted via Mobile Device |
#11 | |
Sounds like the perfect setup for McDonalds's drive through
