Old 07-10-2013, 11:21 PM   #1
dujobu
Headers Help
Anyone have any recommendations for a slick looking pair of headers that will fit in a '71 Blazer with no lift and not require any modifications to anything on the truck? Trying to keep it simple here. Any advice is appreciated.
dujobu is offline   Reply With Quote
Old 07-11-2013, 01:14 AM   #2
4pilgrim4
Re: Headers Help
Several years ago I did an engine rebuild on a tired 350 in my trusty 78 4x4. The goal was to maximize low RPM torque for trailer towing. To achieve this one of things I did was to go with try-Y headers. I got mine from ''Stan's Headers" in Auburn, Washington. They fit up easily to the existing exhaust with only minor trimming of the down pipes. I have no way of knowing how much this contributed to the goal of max low RPM torque but am pleased with the overall result.
I also did the RV cam, dished pistons, got a deal on a Edelbrock sp-2p intake manifold and mated it to the smallest four barrel Edelbrock sells.
Last edited by 4pilgrim4; 07-11-2013 at 01:33 AM. Reason: added the last paragraph
4pilgrim4 is offline   Reply With Quote
Old 07-11-2013, 01:46 AM   #3
Rufton
Re: Headers Help
I finally bit the bullet and installed 3/8" flange, stainless steel, ceramic coated headers in my car. Not wallet friendly but still work and look great after a few years. Thin flange and mild steel may leak and will rust. Stainless doesn't look new as long as ceramic coated. Ceramic coating can burn during high rpm break in or anytime headers allowed to get very hot (roughly 1200F). I ran mild steel exhaust w/ fiberglass wrap for a while and underhood temps were very nice. The wrap will accelerate header embrittlement so I'd avoid on expensive headers. Not clear how long wrapped headers will last; I suppose EGT is a big factor. Ceramic coated headers radiate much more heat than wrapped.
Rufton is offline   Reply With Quote
Old 07-11-2013, 09:21 AM   #4
GhostTown
GhostTown's Avatar
Re: Headers Help
I have a cheap set of thin flanged headers on my '72 right now. They are garbage and came with the truck. Only about a 1,000 miles on a new engine and they've already blown a seal at the collectors once, just from a small bounce over a parking lot speed bump.
I'm switching to Hedman Hedders (proper spelling) this fall. The elite series are 3/8 flanged, and have a unique coupler at the collectors that is fashioned like a ball joint. They can pivot up to 20 degrees so their easier to connect to your existing exhaust.
GhostTown is offline   Reply With Quote
Old 07-11-2013, 11:04 AM   #5
v6wells
Re: Headers Help
hooker headers fit perfect for me
v6wells is offline   Reply With Quote
Old 07-11-2013, 06:30 PM   #6
DANTES JIMMY
DANTES JIMMY's Avatar
Re: Headers Help
I am no means the authority here on this subject
but i think that they are all pretty much junk for a driver
but they sure sound good on a non stock motor
DANTES JIMMY is offline   Reply With Quote
Old 07-11-2013, 08:39 PM   #7
jaros44sr
jaros44sr's Avatar
Re: Headers Help
Whats wrong with good old 2 1/2" cast iron exhaust manifolds....
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-11-2013, 08:53 PM   #8
2003 silverado
2003 silverado's Avatar
Re: Headers Help
Well Jim some of the younger guys want to heard that noise (LOL) Iam with you on the stock cast Irons. On my 03 Silverado I have stock except mangaflow system and wife still hates it LOL
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 07-11-2013, 11:35 PM   #9
jaros44sr
jaros44sr's Avatar
Re: Headers Help
Just seems like they are more of a pita, then they are worth. Back in the day, you would drive to the drag strip, drop your exhaust at the headers, changed to slicks, and went racing. If youre not doing that, why run headers? Your not going to see any noticeable gains on the street...jmho
SAFETY FIRST
AS usual, off topic
Jim
Old 07-21-2013, 10:46 PM   #10
dujobu
Re: Headers Help
Jim, I was thinking of going with headers Primarily because the old cast iron manifolds that were on the truck when I got her were so badly rotted I didn't want to get the same thing and have that happen again. I wanted to go with something more durable and longer lasting. Plus headers look way better the whole time! Am I correct in thinking headers (nice ones) will outlast manifolds?
Old 07-22-2013, 06:51 AM   #11
jaros44sr
jaros44sr's Avatar
Re: Headers Help
Those old rusty manifolds lasted 45 years of extreme duty, and still probably still functioned well...for your money, i dont think you will find a header that will last as long.
200.00 versus 400.00+, i just dont think you will be using your engine in a 5000 rpm range, where the better flow would give you added horsepower....i could be wrong!
Im really not up with the new headers, but they are still just sheet metal, to a degree. Im sure the new coatings help with longevity, but will they outlast manifolds, i dont think so. A new set of 2 1/2" will serve you long after im gone Dont use gaskets, just some copper coat on the mating surfaces, and use the down pipe gasket with the sheet metal sleeve and brass nuts on your studs, and you should have a very good exhaust system. On top of that, if you get seamless stainless steel exhaust tubing, you will further extend the life of your exhaust system. Retorque the mounting bolts after several heat cycles, and use oem locking plates....JMHO
20130722_065558 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 07-11-2013, 09:23 PM   #12
turp mcspray
turp mcspray's Avatar
Re: Headers Help
I put some cheapo Summit headers on my blazer. It was my daily driver, year round, for several years. Never had any grief. My next set will be coated. With plain, you just about need to blast and paint them, every couple of years.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 07-11-2013, 10:32 PM   #13
paul mora
Re: Headers Help
I put Flo Tech ceramic coated on my Blazer about 8 years ago I have had one bolt get loosen blew a gasket easy fix sounds and looks good
Pulatoy
paul mora is offline   Reply With Quote
Old 07-12-2013, 12:52 PM   #14
GhostTown
GhostTown's Avatar
Re: Headers Help
My '65 Pontiac: manifolds. My 50' Chevy C3100: manifolds. My '72 Blazer that I just bought: had headers on it. *shrug*
That's why.
Old 07-12-2013, 05:08 PM   #15
4oldcars
4oldcars's Avatar
Re: Headers Help
I have a set of hedmans form Jegs on my 1971 350. Easy to install. No leaks. Good price. If I can do it, anyone can. I'm runnin a lowered 2 wd and they do drag on speed bumps, but then there should be a law against speed bumps.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 07-22-2013, 06:32 AM   #16
2003 silverado
Re: Headers Help
How old were the Old exhaust manifolds (30 yrs) just my 2 cents
Old 08-03-2013, 11:44 AM   #17
dujobu
Re: Headers Help
So I went with manifolds. Thanks for the info guys. Jim did you have your's ceramic coated? If so, where did you have them done? My local powder coaters don't do ceramic.
Old 08-03-2013, 12:13 PM   #18
jaros44sr
jaros44sr's Avatar
Re: Headers Help
Good choice....no, ive used a stainless steele coating for years on a dd, and it seems to hold up well. Bought it from eastwood.
There used to be a company in norristown, pa. that did jet hot coatings, but i dont know if they are still there
SAFETY FIRST
AS usual, off topic
Jim
Old 08-04-2013, 09:33 PM   #19
dujobu
Re: Headers Help
How hot to manifolds get? I'm looking at ceramic coatings from Eastwood and they are rated for 650º. Is that adequate?
Old 08-05-2013, 06:36 AM   #20
jaros44sr
jaros44sr's Avatar
Re: Headers Help
Not sure how hot manifolds get, but you could call eastwood. Good company, i knew kurt when he started out in a little shop in berwyn, pa.
SAFETY FIRST
AS usual, off topic
Jim
Old 08-05-2013, 08:57 AM   #21
dujobu
Re: Headers Help
Yeah that's the next step. Thanks Jim.
Old 08-05-2013, 08:26 AM   #22
Dale99
Re: Headers Help
I know 650 for headers wont work.
I went with vette manifolds and let them get rusty looking
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 08-05-2013, 07:53 PM   #23
jaros44sr
jaros44sr's Avatar
Re: Headers Help
Or you could do that...
SAFETY FIRST
AS usual, off topic
Jim
Old 08-05-2013, 08:56 AM   #24
dujobu
Re: Headers Help
Found a shop that does ceramic in Middletown, DE but they want $425 to coat the pair. I had no idea this stuff was this expensive. That's a much as a pair of nice ceramic coated headers. Sheesh!
Old 08-05-2013, 07:50 PM   #25
jaros44sr
jaros44sr's Avatar
Re: Headers Help
Didnt know the price either, but im sure it would look cool in the engine compartment, maybe after my truck is done ill come back and do that. In the meantime ill just keep the rust at bay with my cheap coating
Wonder if the ceramic keeps engine bay temps. down?
SAFETY FIRST
AS usual, off topic
Jim
