07-12-2013, 10:05 AM | #1 |
Is this spot OK for a temp sensor??
I want to put my water temp sensor here so the wiring is less visable. I don't have a place on my pre '67 Camelback heads to install this so the intake is my only option. Would this spot be any less accurate than up front next to the thermostat? Thanks!
07-12-2013, 10:07 AM | #2 |
Re: Is this spot OK for a temp sensor??
From what I've been told the best place is right by the water neck, most accurate reading.
1967 swb 454 cid 700R4 trans SOLD 2006 Chevy Trailblazer SS 2013 Camaro RS convertible the wife's Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248 |
07-12-2013, 12:30 PM | #3 |
Thanks. I was thinking the same thing but I had a buddy say anyone of the ports on the intake will be almost identical as far as temp readings go. Also I saw another truck that had it in the back so I started questioning this.
How much of a temp difference do you think there would be between the front port and the back port? Posted via Mobile Device |
07-12-2013, 03:46 PM | #4 | |
Fuzzy |
07-12-2013, 07:58 PM | #5 |
