07-12-2013, 02:54 PM | #1 |
rebuilding the Th350, what are your experience and tips
I'm building my transmission to want handle about 500hp do you have any tips or do you have any war stories or experience just curious?
Posted via Mobile Device Posted via Mobile Device |
07-12-2013, 03:04 PM | #2 |
Re: rebuilding the Th350, what are your experience and tips
Posted via Mobile Device Posted via Mobile Device I forgot to mention my rebuild kit is a street fighter and my converter is a 2800stall
<----Christopher Oh yeah I'm really a Toyota guy, but had some stuff sitting around. Oklahoma Last edited by king-918; 07-12-2013 at 03:31 PM. |
07-12-2013, 05:50 PM | #3 |
Tci kit?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
07-13-2013, 01:17 AM | #4 |
07-13-2013, 02:55 AM | #5 |
http://www.chevelles.com/forums/showthread.php?t=116768
07-13-2013, 09:27 AM | #6 |
clean clean clean
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
07-13-2013, 09:46 AM | #7 |
I had a problem w/ shift kit on other trans.
Simple heli-coil project turned nightmare when drill bit broke. Don't know how to verify if bit is good quality. Meet all factory specs. Do air pressure function checks before mounting valve body. Use vaseline if need to hold parts for assembly. ATF soak clutches. ATF or better assembly lube during assembly. Double check torques w/ accurate wrench. I stripped thread following mfg torque spec. Fill TC before assembly. Verify TC fully seated. |
