07-12-2013, 08:28 PM | #1 |
K30 Cummins Dually build
Figured I'd share my project... everybody loves project threads lol
Mainly posted over at Dieselplace because it originally had a 6.2 in it, but now that I have decided to go with a 6bt they kicked me out lol. Picked it a couple years ago and haven't made as much progress as I would have liked but the C10 and K20 took up some of my time (C10 is gone and the K20 is getting parted out cab is bad) So here is a few pics to start. This is how I picked it up, all torn apart but the frame was blasted and painted The cab had new rockers, cab corners and floors done, not perfect but good enough for a work truck. Originally I was going to put a dumping flatbed on it but money got tight and I had to sell it so now I am going with a mason dump body. The 6.2/TH400/NP205 Combo that was out then back in and back out again. Teaser pic of the 6bt/4RH/NP205 that went in. Have more to post soon. Here is a few pics of my friends 71 K20 that is getting a 3-53 Silver T Detroit I will start a thread on that build too.
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
07-12-2013, 08:45 PM | #2 |
6>8 Plugless........
Re: K30 Cummins Dually build
Cool projects for sure! I like the 3-53's with a turbo. Good little engine for sure. I like the powertrain combo in your truck too. I'm sure you won't regret it either. Haha
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-12-2013, 08:57 PM | #3 | |
It was rebuilt by Mopar (is that ok to say here lol) in 2007. More pics Had a Banks setup on the 6.2, I sold it to buy Cummins parts Painted the firewall and inside of cab, going to be Silver with a black dump Back of cab with color on it, wasn't being to picky on dings and dents here with the dump body going on it, the one big dent is pretty much gone. Inner fenderwells painted and test fit Radiator support mock up, later on I cut the supports out to fit a 2nd gen Dodge intercooler. This is the flatbed I was going to put on it, but I have since sold it.
07-12-2013, 10:47 PM | #4 |
Looking good!
07-12-2013, 11:01 PM | #5 |
Looking good man. Cant wait to see more!
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
07-13-2013, 06:01 PM | #6 |
Looks like a great start for sure! I really like the K30 Reg cab dually trucks. I tried to find one for a long while but just couldn't make it happen.
It looks like you have mixed 1st Gen and 2nd Gen pieces. Did you acquire them separately? Can't wait to see more.
BRIAN 1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater. My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509 |
07-17-2013, 06:16 PM | #7 |
Junk Yartist
I love the 3-53!!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
07-19-2013, 06:06 PM | #8 |
can you elaborate on what the plan is to put a 205 on the back of this trans? it looks like a 32 spline with a figure 8 adapter. interested to see whats the plan for that. |
07-19-2013, 07:09 PM | #9 |
Junk Yartist
the shifter and boot look like late model SM465 and they had 32 spline outputs... I'm just too lazy to go look at my first gen 465 and see if that's what it is.
07-26-2013, 11:18 AM | #10 |
The sm465 is out of my 84 K20, originally his truck had a 10 spline output
07-28-2013, 03:55 PM | #11 |
More Pics
Pulled out the 6.2/TH400/NP205 To drop in a 6bt/47rh/np205 Sitting in the frame
07-26-2013, 11:17 AM | #12 |
I had a 32 spline 205 from the th400 that was in my K30 I sold to him, trouble is the bearings are different sizes so he cut up another tcs to trans adapter and is going to weld it on to the other one.
07-19-2013, 07:18 PM | #13 |
It is but how were they gonna put a figure 8 205 on it?
Posted via Mobile Device |
07-19-2013, 07:35 PM | #14 |
Junk Yartist
Oh yeah! Round pattern for that. Brain fart
08-26-2013, 04:14 PM | #15 |
Some updates, burb seats I am going to use
Some more mockup with the cab and rad support Progress as it sits today... I drove it to this spot... it RUNS and MOVES!! A vid... Now my tranny cooler/exchanger has a pin hole and is leaking $30 a gallon atf argh
08-26-2013, 04:49 PM | #16 |
That's awesome! Great video too. I can't wait till I get to this point in my project.
How much fan clearance do you have to the rad? Looks like the rear valve cover has lots of room. Your setup is almost the same as what mine will be.
08-26-2013, 04:54 PM | #17 | |
Clearance on the back is tight between firewall and trans adapter on the motor.
08-26-2013, 05:45 PM | #18 | |
08-26-2013, 09:08 PM | #19 |
No it was a 93 IC motor, but I got the intercooler and piping from a second gen, didn't even have to cut any of the pipes, I put the intercooler in between the support and radiator.
10-06-2013, 04:50 PM | #20 | |
Any other updates?
10-06-2013, 06:25 PM | #21 | |
Hopefully if mother nature cooperates... next weekend.
08-26-2013, 05:14 PM | #22 |
Looks and sounds great! What did you end up doing for the trans linkage from the chevy stuff to the dodge?
08-26-2013, 05:32 PM | #23 | |
I took the spare tire bolt I had laying around and cut the head off, ran tap all the down, drilled a hole in the frame that lined up with the bracket on the 47rh. Used some nuts+washers to sandwich the linkage levers from the th400 and the linkage levers from the 47rh. Works good, needs a little adjusting then I will weld it up.
08-26-2013, 05:44 PM | #24 | |
08-26-2013, 09:12 PM | #25 |
Also lucked out on the rear driveshaft, originally it had a 2 piece with a carrier bearing.
With the length of the 47rh the yoke on the transfer case moved back so far it was almost even with the back of the cab. So I hunted around and found a 2002 4x4 Ford Ranger with extra cab long bed and a 4.0 auto had just about the right length I needed. Have about 1-1/2 inches of travel on the slip yoke. Had to get conversion u-joints though.
