Old 07-12-2013, 09:43 PM   #1
jpaez 80c10
1980 flatbed cab n chassis frame
is it possible to put a regular bed on a cab n chassis would it bolt up or would you have to do some major work to fit the reg bed on the frame?
jpaez 80c10 is offline   Reply With Quote
Old 07-12-2013, 09:50 PM   #2
83swb
Re: 1980 flatbed cab n chassis frame
If the cab and chassis frame has the same wheelbase as the pickup the bed came off of, then yes it will. You may have to drill mounting holes, I believe there are either 6 or 8 bolt holes in a long bed, very simple task.
83swb is offline   Reply With Quote
Old 07-12-2013, 09:56 PM   #3
jpaez 80c10
nice yea I got a few extra parts laying around im driving the c30 and its about 7100 lbs with the flat bed so i was thinking of swapping the bed out i would have to put the humps on the longbed tho for the dual tires
Old 07-12-2013, 10:00 PM   #4
rs74
rs74's Avatar
I think a regular truck with an 8' bed is 56" from cab to center of axle and a Cab & chassis is 60" from cab to axle. So is you have a C&C then a bed will not just bolt right up.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 07-12-2013, 10:05 PM   #5
jpaez 80c10
i gotta check it out i haven't measured it thanks for the info guys really appreciate it
Old 07-12-2013, 11:40 PM   #6
Brockwaykid
Brockwaykid's Avatar
yes, dually chassis are longer than 8" box srws. my unvle learned the hard way making his pulling truck. out came the torch and welder. we fixed that problem.
Jeff Shaw
2003 Chevy 2500HD LB7 Duramax
Brockwaykid is offline   Reply With Quote
Old 07-12-2013, 11:52 PM   #7
jpaez 80c10
I see thanks
bed repair, flatbed, longbed
