07-17-2013, 03:08 PM | #1 |
Fresh 327 short block
I have a fresh 327 short block which I bought from another board member.
Was going to use it in a project but dont have the time or money now. Asking $850, here is the description: 1968 impala 2 Bolt main, large journal crank and rods NEW PARTS: not installed, in boxes Cloyes double roller timing set #C-3023X New harmonic balancer Sealed Power lifters(16) #HT-817 Mr Gasket chrome timing cover set #4590 NEW PARTS in assembled short block Duralast cam bearings Mellings standard oil pump and pick-up Molly rings flat top pistons rod bearings main bearings rear main seal oil pump drive shaft , heavy-duty metal Comp Cams 12-210-2(49) LABOR & MACHINE work recheck all clearances and machine work Hot tank block paint block and oil pan chamfer bore tops chamfer all bolt holes bottom tap all threads clean, resize and install new bolts in rods install new cam bearings bore and hone .30 over assemble pistons to rods and install rings assemble short block slide in cam, install pistons into bores, install crank, torque everything to spec, install oil pump and new drive shaft, install new pick up(set to fit oil pan) Any questions pls LMK, pics available upon request. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
07-18-2013, 03:15 PM | #2 |
Re: Fresh 327 short block
ttt
